Question about Sewing Machines
Serger Stuck I was just given a White Superlock 523. It gets stuck as the needle goes down. I have taken it apart and can't seem to find the problem. The needle and loopers clear each other fine, the motor is fine too. Any ideas what the problem could be? I have tried it threaded, and without thread and it doesn't work either way. Thanks
    Sergeant:
    Champion:
  • 334 Answers
The first thing a machine needs is oil. Absolutely soak everything that turns. My upholstery machine sits for a while and it gets stuck too. Believe me you don't just turn it. The tolerence is so close its just hard to get broke loose. Use a spray that absorbs rust. then oil good when done
Posted on Dec 05, 2008
White Superlock serger continually breaking needles
First take all the thread out of the machine. Put in new needles and run the machine slowly by hand and see if there is a problem with timing. If the needle hits and bends or breaks... take it in to be timed. If the needle don't hit....
Make sure you are properly threading this thing. Unlike a sewing machine which gives you some leeway, Sergers must be threaded in a certain order. Typically, upper looper, lower looper, right needle left needle. If you break a thread you can't just rethread that thread... you have to start from the beginning.
You might check singerco.com for the manual for this thing. They have most of white's manuals online they are identified by a W before the serger model number.
Oct 04, 2012 | White Sewing Superlock 1934D Mechanical...
Left needle thread keeps breaking on my White Superlock 2000 ATS serger
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
May 02, 2010 | White Sewing Superlock 2000 ATS Mechanical...
What is the size of the needle used in the white superlock 1934D
This is a very highly regarded serger. Check out the reviews on http://sewing.patternreview.com if you're interested--but they are all extremely positive.
I also checked out the White Sewing Machine site--the three sergers they currently sell all use regular sewing machine needles.
Based on what I read on both sites, I believe your machine also uses regular sewing machine needles (not all sergers do, BTW). To be absolutely certain, you can call the White Help Line (l 800-331-3164, Monday through Friday 8AM to 5PM, EST).
If your serger uses regular sewing machine needles, then the size of the needle depends on the type of fabric you're sewing. Sizes 8 to 10 for lightweight fabrics, 12 to 14 for medium weight fabrics, and 16 to 18 for heavy weight. Use ballpoint needles for knits, jeans needles for denim, and universal needles or sharps for woven fabrics.
Jan 26, 2010 | White Sewing Superlock 1934D Mechanical...
I lost my instruction manual fro my serger white
I found a free pdf manual for my 20 year old White serger at singerco.com. Hopefully you can find yours too.
Jan 26, 2010 | White Sewing Superlock 2000 ATS Mechanical...
White Serger 1934D not stitching
No, Sounds like the loopers are not passing properly to pick up the thread, from off the needles.
Jan 11, 2009 | White Sewing Superlock 2000 ATS Mechanical...
I need instructions to Thread a White Super Lock 534 Serger
I hope this helps. there a lot of other vidios you can try as well. DFD
Jan 04, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Threading my whites superlock 2500 serger
You can get sewing machine manuals online at sewingmanuals.com. I didn't see the superlock 2500 but there were other superlocks. They may thread the same way.
Jul 30, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
170 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
