Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Neon Pink outlines around bright images
I have had this pt-61lcx65 for a year this month. I turned it on one day last week and my son noticed all the neon lighting outlining things that were the brightest on the screen and sometimes neon pink over some images in full. Had a repair man come out (75 bucks for just coming) and now am being told that I need a whole new sercuit board. Cost being 1350.00???????? that was insance. He suggested that I call panasonic and raise a frenzy. Do you see the repair guy being correct? He did not open anything on the tv. Only looked at teh screen. Asked some questions and that was it!!!
  • 4 more comments
  • nicole wicherek Jan 31, 2007
    Here is a picture of a white shirt and you can see all the neon pink on it.
  • Bluffhawg Dec 27, 2007
    I have Neon Pink outline on bright color pictures (mostly on white). It also appears that peoples faces are starting to flush (lose color).
  • Enoch_r Jan 06, 2008
    I have pt 61LCX35 and mine just started the same thing only it's blue not pink but looks just like your photo. Any help out there to what this is.
  • Anonymous May 02, 2008
    I have the exact same problem with my Vizio VX32L. Fortunately its under warranty and I should be able to have them fix/replace it.
  • dmill Jun 02, 2008
    I have the same problems on a Samsung LN-T5265F. I have resorted to turning the backlight brightness down and it keeps it from happening, however i have to sacrifice picture quality.
  • Anonymous Jul 17, 2008
    It leaves two points one green and another pink one in the screen Panasonic PT-61LCX65 as it is the solution.
Had the same problem. Along with the spots from the EPROM corrupting. Called Panasonic and they had a local tech come out and flash the EPROM. Now TV is as good as new and I didn't have to pay a dime.
Posted on Apr 21, 2010
I have this piece of **** tv too. Kicking myself because I could have bought a plasma tv for $500 less with a slightly smaller screen. Now I've this big piece of junk to haul to the dump.The picture is awfull with colored spots..........changing the bulb did nothing, the spots are still there.
Posted on Dec 08, 2009
I had the same problem with the red/pink outlines around images. i fixed it myself by removing the read lower pannel with all the screws that have arrows pointing to them. then using a can of compressed air blew out the pc board on the left of the tv, if u r looking at it from the back. there is a spot in particular, where there is some chip that attatches to the board and there is a gap that was full of dust. after that was clean the red outlines where gone. hope this helps u also.
Posted on Nov 09, 2009
I called panasonic and they are sending a tech out to check the TV & repair it. My TV is 3 yrs old and they said they've been having problems with this model and are giving me a one time in-warranty correction to the problem. Try calling them. Good luck.
Posted on Sep 15, 2008
I was told by a Panasonic Dealer that the color engine has dust in it. The part is approx. $800 or $900, not including labor to install. I moveded the TV to a back bedroom & bout another.
Posted on May 12, 2008
QTV1 is Panasonic's service tech and knows what he's talking about thank you Quality TV
Posted on Jan 08, 2008
  • 87 Answers
You have a defective optics block assembly. If the set is less than 1 year old it will be covered under warranty. If it is over 1 year old try calling Panasonic customer srvice at 800-211-7262 to see if they will assist with the cost of the repair.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jan 07, 2008
Two points one green and another pink one in the screen Panasonic PT-61LCX65
Posted on Oct 05, 2007
SOURCE:
Colour spots on pt-61lcx65-k panasonic tv
Need to have a service tech come out and calibrate the TV. I had spots on my screen and the tech came out and hooked his computer up and calibrated it and it worked fine afterward.
Feb 24, 2013 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61 -- Neon Yellow Lines
I called Panasonic and they are sending a repairman. My TV is 3 years old. They said they'd cover the repair as a one-time in-warranty even though it is out of warranty because they've been having problems with this model. Don't do like me and try to live with the problem.
Good luck to all that have this problem.
Sep 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65
Per panasonic's autorized tech website it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software upgrade.
Correct symptoms using part LSUQ0100 jig that comes with instructions. (operation takes 6 mins)
Hope this helps.
Mar 24, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Neon Pink Lines
"eprom upgrade" by Panasonic tech will solve the problem.
Jan 13, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
817 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
