Question about Dell Latitude D600 Notebook
Problem connecting my dell latitude laptop to my tv
I used a 7 pin s-video connection to connect the tv to the laptop and when I first turn the lapttop on the picture shows on the tv for about 10 seconds then goes black, but my laptop operates normally.
  • jtdx82 Dec 02, 2008
    It shows 2 default monitors and both are enabled.
  • 64 Answers
Check the monitor settings under "Display Properties/Settins/Advenced/Monitor" (right click on desktop).
Posted on Dec 02, 2008
  • Farhang Mobarhan
    Farhang Mobarhan Dec 02, 2008
    Try another s-video cable.
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
S-Video Connecting Laptop and PC
The best way is via the VGA connector on the computer and by connecting the Audio out on the back of the computer to the RCA sockets on your TV. You will need a 3.5 mm jack to stereo RCA cable for the audio.
May 05, 2013 | Computers & Internet
Laptop S-Video to TV S-Video?
S-video and a 3.5 mini male to dual RCA male: http://www.bhphotovideo.com/bnh/controller/home?O=&sku=808831&Q=&is=REG&A=details From Laptop headphone jack to stereo input on TV.
May 05, 2013 | Dell Inspiron Computers & Internet
My dell 510 only show DELL on tv nothing else from my laptop
What Operating System and version are you using (i.e. Windows XP, Windows 7, etc)?
If Windows, you will ultimately have to go to Control Panel > Display > and choose to extend your laptop screen to the connected device. These options are in slightly different places across different OS versions so it may take some digging around to locate the option to extend display.
Feb 13, 2013 | Dell Latitude D510 Notebook
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Feb 17, 2010 | Dell Latitude D600 Notebook
Can I connect my dell latitude d360 laptop to my tv?
When you connect the VGA cable to the TV you will need to hit the FN button + F5 on your keyboard, that will change the dispalys from internal to external. if you hit FN+F5 again you can have both the laptop and the TV screen on.
May 31, 2009 | Dell Latitude D600 Notebook
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
Conection to TV using S-video on Dell D600
Google this and read the forums... d600 s-video out
Dec 10, 2008 | Dell Latitude D600 Notebook
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
180 people viewed this question
Alun Cox
