Question about Mitsubishi WS-55805 55" Rear Projection Television
Mits WS-55805 won't even turn on. Did have sound,but no sound now
We need to find a copy of the Service Manual (online, if possible, for quick retrieval) for the WS-55805 Projection TV. First the picture went, but you could still turn it on and hear sound; then the sound went also, and now you don't even hear the static of it turning on. My husband was an electronics tech in the Navy and is our in-house mechanic/repair-man, but we can't find the service manual. Anyone have it online, can point us to it or can email it (or a working link) to us?
Thanks!
D
  • hugoloco Apr 10, 2009
    TENGO UNA MITSUBISHI Y DESDE ANTIER NO LA PUEDO PRENDER SE ESCUCHA QUE HAY CORRIENTE PERO NADA SALA EN LA PANTALLA Y CUANDO LA APAGO SALE COMO UNA LUCESITA
  • Mitsubishi Master
  • 5,568 Answers
Well, it isn't free but $8 is cheap for just about any service manual:
WS-55805 Service Manual
Posted on Dec 02, 2008
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
I've had my Mistsubishi 55"
The main board has an issue which has most likely blown a fuse. Those boards have been discontinued so repairing that one will be at least a couple hundred depending on the shop doing it.Or yo umay be ble to locate a used one on ebay .
Jun 24, 2011 | Mitsubishi WS-55805 55" Rear Projection...
I have a WS-55805. Was working great, then suddenly no picture, just audio. When I press the Menu button, I get the menu but I see three separate colors for each menu item. Could this be the lamp, or...
This TV does not have a single lamp but a set of CRT tubes.
If you get menu displayed on wrong clors or colors are not matching then it is either a bad CRT, a bad CRT high voltage power board, or sometimes a problem with convergence board and convergence ICs, however in this last case you usually get no picture and no sound .
You can get service manual from link below:
Mitsubishi - CRT Projection Television - WS-55805 Service Manual
Apr 10, 2009 | Mitsubishi Televison & Video
2004 Mitsubishi WS-55813
You need the V23 Chassis DM repair kit which has the replacemnt capacitors and the instructions on how to do the repair. Heres the link to the kit. You also get the full service manual on the instructional CD as a bonus.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 16, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Won't turn on
If the LED never stops blinking, you have a failure in the DM module. It is usually caused by 4 or 7 1000uf capacitors going bad inside the module. Mits says to replace with 680uf 16v caps to fix..
Dec 16, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Online repair manual for mits 55805
Good Day, TraderGordo;
I will E you the info.
Good Luck, big IRISH.
Aug 14, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Power on and off
you would need to trouble shoot the standy voltages and see whats happening with them. I would suggest getting a service manual from the following link as they will email it to you quickly after purchase and they will provide free tech support to help you diagnose and repair your set. Heres the link.
May 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Suddenly, Sound But No Picture
that is not and easy problem U need experienced tech to take a look at your TV call a local TV shop
Apr 17, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Geometry - Edges cut off
1)power on TV
2)Push menu-1-2-5-9 in quick succession
3)Use 4-5-6- to change colors
4)Use enter to blink / unblink cursor ( blink = move, unblink =
adjust )
5)Finished? = menu out to save changes
Please rate this solution......................................
Nov 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mits ws-55805 No sound no Pictuer
FIRST CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010 IF STILL NO HELP PROBLEM CAN BE INTERMITTENT (TEMPERATURE RELATED) CAUSED BY IC7D04 PART # 275P245010 ON THE DOUBLER PCB THIS WOULD BE A THIN VERTICAL LINE IN CENTER, IF GUNS WERE ON.
May 21, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
