Question about Ricoh Aficio 1085 Laser Printer
Ricoh aficio 1085 Have relatively new drum and developer, but am getting light copy after corona wire broke and was replaced. Before the break, copy was great. Ideas? Thanks, Ron
  • 162 Answers
Also can be dirty the filter glass located to the right of the Charge corona.
Posted on Oct 21, 2009
  • 162 Answers
When the wire is broken the copy prints generally some copies complete black…
This makes to go down the density of toner in the developer
Try add toner and adjust.
2 207 - Forced Toner Supply
Forces toner supply for 7 seconds from the
toner bank through the toner hopper to the
development unit.
1 Forced Toner
Supply
This mode finishes automatically after the
toner is supplied 7 times (1 s for each
time).
Make one copies
If the Copy is well...
adjust 2-801TD Sensor Initial Setting.
good luck...
Posted on Sep 10, 2009
    Problem Solver:
  • 9 Answers
Have you initialise from service menu that you have changed the corona wire?..have you cleaned the corona wire after replacing with alchool...?
Posted on Dec 09, 2008
    Problem Solver:
  • 7 Answers
Make sure the new wire like broke one i think must be
GENUINE wire
Posted on Dec 08, 2008
  • ma7moud fayed Dec 08, 2008
    make sure Suste linked in the same place
Dark back ground on ricoh affico mp3500 replace drum ,Blade pcr. nothing has changed on the copy
Sounds like drum unit not getting charge voltage to it. Check charge roller is in properly point end should face rear of copier and making contact with plate.
Jan 08, 2014 | Ricoh Aficio MP4500, MP3500 Kit
Como soluciono el error sc300 de la ricoh 2060SP
sc300 on a Ricoh 2060 is a corona wire error. Typically what happens is the corona wire has snapped, and a new wire needs to be installed.
May 28, 2010 | Ricoh Aficio AP3800C Laser Printer
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
May 08, 2010 | Ricoh Aficio Colour 3006 Color Copier
Ft 7950 light copy
Clean the transfer/separator corona unit,the optical unit components and if you have make more 1200000 copies change the developer and OPC drum,drum cleaning blade and the charge corona wire.
Dec 10, 2009 | Ricoh FT7950 Copier
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Ricoh FT7650 Printing LIghtly - Developer Problem?
It isn't a broken corona wire. If that was the case, it wouldn't copy at all and you would have a few error codes as well along with a few sparks.
Dec 22, 2008 | Ricoh Aficio 450 Copier
Aficio 1085 toner pread in drum area
the blade is not sitting correctly either you have used a bad one or the mechanism is not adhereing closely to the drum, removed the uit and rotate towards you sprinkle a few toner if you can still see a remainder toner that was not yet scraped then the prob is really in the cleaning unit, either the blade or the plate,
to ensure have you consider changing your drum? it could be exhausted already...
no other way around it
Nov 28, 2008 | Ricoh Aficio 1085 Laser Printer
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1085 Laser Printer Logo
279 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
