Question about Brother XL-3500
Tension setting XL 3500 Brother
I am not sure what my tension is suppose to be set at
  • 34 Answers
Hi, and welcome to FixYa. Normally, the default top tension setting on most machines is between 4 and 6. Brother manuals usually contain detailed information about tension and how to determine if your tension is set correctly, so check that section of your manual when you have time....if you don't have your manual...
you can find a copy to download for free on Brother's website (I added a link to the web page below). The same web page has other information about your machine that you might find helpful now or in the future. Even if you have the manual, it is worth a visit.
If you and other readers have a minute to rate my answer, it helps me better understand what readers are looking for when they come to the FixYa site for help.
Best of luck, and enjoy your machine. Don't hesitate to comment if the link doesn't' work, or if you have more questions. Cheers!
Posted on Feb 04, 2009
3500 XL. Why can't I get upper tension set correctly?
you bobbin case has a screw.
a small flat head screw
tighten it slightly this should help
the screw is also a tension adjustment
Jul 12, 2015 | Brother Sewing Machines
Does anyone know how to set a Brother sewing machine for a straight low tension stitch?
Stitch length on 2.5 and stitch width on zero, and just loosen the top tension by a half number if you want the tension looser. If your machine has a stitch selector knob, make sure it is set to the straight stitch setting.
Oct 10, 2011 | Brother XL-2600I
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
May 31, 2010 | Brother XL-3500
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Jun 13, 2009 | Brother XL-2600
My four-year-old XL3500 seems to have a tension problem. It was sewing fine until after I refilled the bobbin, changed thread twice, and did some zigzag stitching. Now the top stitch is not correct; it...
according to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to they have a downloadable manual for your machine.
Jun 04, 2009 | Brother XL-3500
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
XL tension setting
Hi - and welcome to FixYa. It sound like your machine is not threaded correctly. Here is the first rule: when you thread your machine, make sure your presser foot is raised up. Never thread your machine when your presser foot is down. When the presser foot is raised, the tension dials open and allow your thread to pass through the dials when you thread the machine. If thread is loose and hard to handle while you are trying to thread, just press down on the thread somewhere near to the top of the machine so it does not slide around. Here is the good news - when you have reached the needle, you can lower the presser foot. Before you thread the needle, pull your thread - if you threaded the machine correctly, the thread should not move. If it does move, you need to start over. If the thread does not move, you can thread you need with the foot up or down, pull the thread under your presser foot and pull it toward the back of the machine. Leave a 2 or 3 inch tail.
If you don't have your manual, you can download a free copy from the Brother web site. Brother manuals have very detailed, easy-to-read instructions. To get to the correct web page, use the link below:
If you and other readers have a minute to rate my instructions, it helps me to better understand what folks need when they come to the FixYa site for help.
If you have more questions, or if the link fails, please feel free to comment and I will answer as soon as I can. Good luck, and have fun with your machine!
Dec 02, 2008 | Brother XL-3500
Brother XL-3500 Logo
204 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
