Question about Brother MFC-7820N Printer
Need to know how to take off scanner unit
What are the steps to take off the scanner unit from a brother mfc 7820n?
  • jcunningham Dec 02, 2008
    the downloads do not show me how- I need the service manual the other pdfs are for the consumer not the tech
  • rsullivan601 Feb 03, 2009
    Scanner locked. Phone call to tech said to try to lubricate the shaft. Need to take scanner glass off to do this. How?
The scanner lid of these units can be removed, but there is nothing that can be addressed when it's opened except replacing the entire scanner bar.
The bar is positioned not by a switch, but by the bar moving under a white reflecting surface on the bottom of the glass. If the scanner cannot sense this white strip, it bumps against the end of the lid until the error is generated. The failure indicates a failure in the scanner bar or the circuit it is connected to.
Beverly Howard
Posted on Apr 16, 2011
    Scholar:
  • 191 Answers
Download the pdf and check it out step by step info
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-7820N
Posted on Dec 02, 2008
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
How do i use the scanner on CLX3175 COPIER
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-DCP-7010L-DCP-7025-MFC-7225N-MFC-7420-MFC-7820N-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Mar 30, 2010 | Brother MFC-7820N Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Brother 7820N has black vertical line when using ADF
It's the same scanner ccd, after you make sure the narrow scanner window is clean, you need to power down the machine and power up again so it will calibrate to a clean window, if it has a scratch like from a staple, you will need a new glass.
Jan 18, 2010 | Brother MFC-7820N Printer
Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Scanner
Check smaller slit glass panel near copy top glass (open lid on left for liquid paper / dirt.
Oct 30, 2007 | Brother MFC-7820N Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
238 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
