Question about Brother XL-3500
XL tension setting
I am not sure what the tension is suppose to be setting at. I was wondering if there is a tension where the bobbin is or could it be I am threading my machine wrong. I could pull one of the threads and it will come apart. None of my stitching is tight.
    Scholar:
  • 34 Answers
Hi - and welcome to FixYa. It sound like your machine is not threaded correctly. Here is the first rule: when you thread your machine, make sure your presser foot is raised up. Never thread your machine when your presser foot is down. When the presser foot is raised, the tension dials open and allow your thread to pass through the dials when you thread the machine. If thread is loose and hard to handle while you are trying to thread, just press down on the thread somewhere near to the top of the machine so it does not slide around. Here is the good news - when you have reached the needle, you can lower the presser foot. Before you thread the needle, pull your thread - if you threaded the machine correctly, the thread should not move. If it does move, you need to start over. If the thread does not move, you can thread you need with the foot up or down, pull the thread under your presser foot and pull it toward the back of the machine. Leave a 2 or 3 inch tail.
If you don't have your manual, you can download a free copy from the Brother web site. Brother manuals have very detailed, easy-to-read instructions. To get to the correct web page, use the link below:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl3500t3510eus.html?reg=us&c=ca&lang=en&prod=hf_xl3500t3510eus
If you and other readers have a minute to rate my instructions, it helps me to better understand what folks need when they come to the FixYa site for help.
If you have more questions, or if the link fails, please feel free to comment and I will answer as soon as I can. Good luck, and have fun with your machine!
Posted on Feb 04, 2009
  • talk2ginny
    talk2ginny Feb 05, 2009
    Hi - how is your machine? Do your stitches look better? Let me know if you need more help - just write up a comment and describe what is happening - we'll get you up and sewing!
Bobbin thread just pulls through. St itch looks fine, but the bobbin thread pulls right through?? I have tried a couple different bobbin cases, all supposedly for the 1630???
Not sure, but it sounds like the top thread may not be seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Set the top tension to the midway point and test your stitch. Then tweak the tension.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 27, 2017 | Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Bobbin thread too loose moves fast when thread is pulled
***Adjust the top thread. It must be fed through the tension properly. It is best to feed the thread with the pressure foot up. While threading the machine give small tugs to check for stuck areas. Fix these even if you have to replace the thread.
***Don't thread needle yet. Now, Set the pressure foot down. Give small tugs. There should be some tugs. Adjust the tension up and down while doing this to make sure the tension is functioning.
***Thread the needle and set the tension to four. Adjust if necessary as you sew.
That is your problem. However, I've placed a guide how to set the tension of the bobbin.
Oct 08, 2015 | Brother XL-2600
My top thread has large loops on the bottom, bottom thread is normal. I have tried to adjust the tension but it does not help
The bobbin also has tension adjustment. Take bobbin out and try making it tighter. Also make sure thread is threaded properly on bobbin.
Mar 02, 2015 | Sewing Machines
Brother LB6800PRW Bobbin Tension?
I suggest having the top tension checked by a sewing machine technican,, and since the bobbin case screw is painted with green ,, I suggest having it checked also to make sure the tension is correct on it. also make sure the bobbin is inserted correctly--counter clock-wise..
Dec 17, 2014 | Brother LB-6800PRW Project Runway Limited...
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Skipped bottom stitches
try changing the needle
make sure the bobbin is not warped
make sure the bobbin is turned the right way in the bobbin case
make sure the top tension is adjusted correctly
make sure the top and bobbin thread is the same
Feb 01, 2013 | Brother XL-5130 Mechanical Sewing Machine
Can you tell me what the initial tension settings should be for a Brother xl2600i?
try a new needle
rethread the machine top & bobbin
make sure the bobbin is inserted into the bobbin case correctly
it's also possible that the machine could be slightly out of time
& a sewing machine technican would have to check the machine
to see for sure
Aug 06, 2012 | Brother XL-2600I
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
May 31, 2010 | Brother XL-3500
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
Brother XL-3500 Logo
214 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
