Question about HP Officejet 5610 All-In-One InkJet Printer
COPIES COME OUT WITH LINES THROUGH THEM
SCANNER IS FINE I CAN SCAN TO COMPUTER AND SEND PRINT BACK WITH NO PROBLEMS
    Problem Solver:
  • 5 Answers
Your printer is most likely getting low on ink
Posted on Aug 02, 2010
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Problem with brother mfc 7340 copier: when i copy, two parallel lines appear on copy. thanks for your answer
1. To test, print the Help List:a. Press the REPORTS key located on the control panel.b. Press the up or down arrow key until Help list appears on the display(#2).c. Press Ok. The report should begin printing.Black lines that appear on faxes you send, images you scan into the computer and copies you make are typically caused by dirt or white out on the scanner unit. The scanner unit is the mechanism that reads in the documents that are being copied or transmitted.
Nov 27, 2011 | Office Equipment & Supplies
CANON PIXMA MP810 PROBLEMS - Aghhhhh!! I can
Try this,
scan the document to the computer, then view it using a picture viewer.
You may see that the scan is faulty!
The printer may be printing exactly what it sees!
Mar 07, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Skipping lines
you should run a printer head cleanup and verify your cartrages are all full
Feb 09, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
