Question about HP Office Equipment & Supplies
Scanner error 5 - HP Office Equipment & Supplies
Iam getting scanner error 5 on my hp 2840 printer. please tell me what to do. my e-mail address is charlesejekks@yahoo.com
Posted on Feb 19, 2009
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Scanner error 5
Scanner error 5 is caused by a bad formatter that in turn destroys the scan axis motor in the scanner itself. The formatter is covered under a warranty extension by HP but last time I checked they were no longer covering the scanner motor. Contact HP at 1-800-invent
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Scanner error 5
Based on the service manual the Error: Scanner Error 5 doesn't exist. However 52 Scanner Error exists. If the scanner doesn't function anymore the recommended solution is to replace the scanner assembly.
Oct 20, 2010 | HP LaserJet 2840 All-In-One Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP M1522nf printer, shows "scanner error 5"
I have the same problem, could you pl let me know where can I get the stepper motor?
Dec 08, 2008 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
738 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
