Question about Hasbro Fur Real Friends Smores Pony
Horses mouth I need a repair service for a 2 1/2' x 4' mechanical horse whos bottom jaw was broken... Any suggestions?? Larry
  • Anonymous Dec 07, 2008
    I have the same problem and looking to maybe peal back the head.
  • Anonymous Dec 15, 2008
    Same thing here - mouth hangs open as if the horse had a stroke.
    WHY is a $300 toy such a piece of .....
  • 3 Answers
I had the same problem with mine. There is **** in the upper part of the horses mouth if you gently pull it open a bit and look inside to the jaw area you can see where to reconnect the jaw and pop it back in place. There is also a wire connection near the mouth, so check and make sure this is also connected.
Posted on Dec 30, 2008
Whats is the difference between a paint and a pinto?
Paint Horses can only have the bloodlines of Quarter Horses, Paint Horses or Thoroughbreds in their pedigrees. ... On the other hand, "pinto" is a term that refers to the colorful coat pattern and is not the name of a particular breed of horse. Any horse that displays one of several coat patterns is considered a pinto.Mar 2, 2010
Question of the Week: Paint vs. Pinto - Horse Channel
www.horsechannel.com/horse-exclusives/paint-vs-pinto.aspx
difference between paint and pinto Google Search
Feb 15, 2018 | Cars & Trucks
Replacing bearinon spindle housing
Remove deck and place on two boxes or saw horses so that you can access both top and bottom of bolts holding spindle housing. Remove drive pulley from spindle. Remove cutting blade. Remove four bolts holding spindle housing to deck frame, noting which way grease nipple is pointing. Take spindle housing off and scrub deck frame clean of rust etc and also clean housing with wire brush. To remove bearings, look for retainers such as nuts or circlips. Remove these and ensure that the shaft is clean so bearing can be slid off. Apply CRC or light oil to assist bearing removal. Use a vise and set jaws wide enough that the bearing outside can fit between. This is usually 45 to 50mm. [1 3/4" to 2"] Place a hard wood block [or something that will not bruise the thread such as solid nylon] and screw nut well on to thread but make sure there is space for movement between nut and bearing. Firmly tap spindle end. Shaft should go down into top bearing and bottom bearing should start to emerge between vice jaws. Make sure that there is always space between nut and bearing before knocking end of shaft again. To knock top bearing out, place it on bottom over vise jaws and take a length of wood such as a section of broom handle and knock it out. Normally there should be no seals on the inside of these spindle bearings as they are greased from a grease gun thru the grease nipple.
Sep 26, 2014 | Garden
Can a dentist treat a broken jaw?
There are some less severe cases of broken jaws that most dentists can treat although in most cases you will need to visit the emergency room of your nearby hospital.
Feb 03, 2013 | Health & Beauty
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
I have a 1997 Chevy C1500, 5.7L 350, 2 wd. It says to use Dex-cool, but I've heard a lot of problems about it. Can I use the regular green coolant or do I have to stick with orange dex cool?
You should speak with the Chevy Garage in your area for the very latest on the Dex-Cool issue. I wouldn't use the green stuff unless the Service Garage said it was OK. ... and I say this having heard the same stories you have heard and being a Chevy C2500 owner. Get the straight word straight from the horses mouth.
Thanks for your question @ FixYa.com
Aug 09, 2011 | 1997 Chevrolet C1500
There are 25 horses and 5 tracks in how many times the race was conducted among 25 horses by arranging them in 5 tracks to find the best horse among 25 horses
Run 5 races, with 5 horses per race.
Thus, all 25 horses have competed exactly once.
Pick the winner from each of the 5 race,
and run one more race, namely a 6th race, with those 5 horses.
The winner is the fastest horse of all 25 horses.
Sep 26, 2010 | Computers & Internet
Hasbro Fur Real Friends Smores Pony Logo
187 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
