I am trying to connect to a imac computer via DVI-D cable. It wont display.
    Novelist:
    Champion:
  • 233 Answers
So you are trying to use dual monitors? I think there is something in (System Preferences: Displays: Detect Displays) that will allow you to do this.
Posted on Dec 29, 2008
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
My imacs screen wont show up what do i do?
get an external monitor and the correct dvi adapter and plug it in to te back and turn it m Make sure that in the >System Preferences>Displays you have mirroring turned on then you should be able to a least use your mac. My sister had the same problem this solved it somewhat She hides the iMAC behind the new screen. Only other solution would be to take the iMAc in and probably have the display board replaced which would cost you more than the new screen. You will still have the new screen to put on a new computer and use it as a second display.
I have two 24 inch displays on my computer
Oct 21, 2012 | Apple iMac G5 Desktop
How do I connect my iMac 27" i7
You can buy an optional cable that you can plug into the mini-DVI or mini-displayport port at the back of your iMac.see example picture on: http://www.ecoustics.com/electronics/products/new/570842.jpgFirst you need to be sure to know exact if you have a mini-DVI or mini-displayport. The connectors are different and depend on how old your iMac is. Than you can buy the connector that fits your Mac. The you only need to check the connections on your TV. HDMI or DVI will give the best image quality. VGA is older and will result in a lower image quality. Last, you need to buy a cable between the adapter and your TV.
Jun 12, 2012 | Apple iMac Z0GF0005F Desktop
I would like to remove the OSD warning pop out "Attention" from my monitor. What I need to do to achieve this?
If you are getting a message that says something like "Check cables" " no signal detected" or something like that, it is likely that your monitor is operating correctly. I would suggest checking your cables, make sure that the computer is turned on, and if that doesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I am thinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables are typically blue.
Another common connection that is used is a digital HDMI (left) or DVI (right) connection. DVI cables often have white end connectors. How your PC connects to your monitor will determine the source mode you want to use on your monitor. (Obviously this is the cable view but the connection on the monitor itself will look similar.)
If none of these tips helps, I would suggest hooking the same monitor up to a different PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on your monitor. If it works on another PC, then your computer may have a video problem.
Otherwise, if it still does not work your monitor have a problem displaying via that connection. If possible I would suggest switching to a different type of cable and re-try the above steps.
Mar 20, 2011 | AOC 193FW LCD Monitor
My Blue-Ray wont play on my VX2035WM Monitor
Try connecting the monitor to your computer via a VGA cable instead of DVI. (The blue instead of white cable)
Mar 01, 2011 | ViewSonic VX2035WM LCD Monitor
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
I would like to connect an Apple Studio Display 17" to my Macintosh Server G4. Can it be done? What adaptor is needed if any?
Apple Studio Displays connect via DVI cables. The PowerMac G4 (all versions) support both VGA & DVI. You shouldn't need any adaptors. It should just plug into the back.
Dec 22, 2010 | Apple Macintosh Server G4
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
