We have a HP Officejet Pro L7580 - all in one fax/copier. It has a cartridge jam. I don't even know how to open this up to remove the jam and the book which came with the machine tells only how to set it up...no help on how to remove the paper tray...get into the jam...etc. Can you please help me? This is the only fax machine in-house. Karen
    Genius:
  • 2,120 Answers
If I recall correctly, you lift up the gray cover closest to the paper tray.
Your user manual is on the CD that you got with your OfficeJet.
Or...go to www.hp.com for detailed help.
Posted on Dec 02, 2008
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Where do you find a driver for the Officejet Pro L7580 for an Mac
Good Day Nicholas!
You can find the HP Officejet PRO L7580 driver for MAC from the download link below
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=2512008#N199
Please don't forget to rate my answer.
Jul 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
It gives the message ,remove paper jam, even when there was no paper in the tray when it was turned on.
MAY BE SMALL PARTICLES OF PAPER MIGHT JAM IN THE PRINTER..........OPEN WITH THE HELP OF TECHNICIAN
Mar 21, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Won't fax without ink
This is a Inkjet printer, i needs ink cartridge to be filled to function properly.
Please replace ink cartridges. You cannot print with one ink tank.
Regards,
Riztech
Mar 04, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Fax jam. 1/2 sheet through, 1/2 stuck. How can I get the sheet out?
Turn the printer around and remove the back lower cover or the duplexor and you should be able to remove the paper.
Aug 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp l7580 carriage jam - how to fix it
use the back door for printer and you can remove the envolupe
May 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP OFFICEJET PRO L7580 PRINTER WILL NOT RECEIVE FAX
Is the machine set to auto receive?
Try unplugging the power for a few seconds. This may clear any data that is "log jamming" the memory.
Apr 22, 2009 | HP Office Equipment & Supplies
Labels Jammed in printer HP Officejet PRo L7580
I’m really embarrassed, my husband released a latch which right above the ink cartridge and the whole fax machine open up on it’s hinges these was my labels.
Dec 17, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
64 people viewed this question
jasbo
jasbo
