Question about Panasonic RR-QR150 Digital Voice Recorder
Cannot record When I push record the display as full for all areas
Harley trouble shooting
First, check for any error codes:
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's.
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
If you DO get any error codes, repost them for diagnosis.
Aug 05, 2014 | 2006 Harley Davidson FLHR Road king
2006 road glide stalls
First off, did you pull any error codes?
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
Jul 21, 2014 | Harley Davidson FLTR-FLTRI Road Glide...
What does daignostic code dia9 mean?
The IM (instrument module) is capableicon1.png of
displaying DTC's (diagnostic trouble codes).
1- Ignition off
2- push odometer reset
button in & hold. Make sure run switch is on.
3- turn
ignition to run and release button (you will see P, S &C displayed)
4- each letter represents an area of diagnostics... the one that
is flashing is the one you are going to check. To move from one letter to the
next, you push the button one time. (from P to S to C and back to P, etc.)
5- to get DTC within an area, you push and hold the button in
for 5 seconds and if there are any, it will be displayed... you can release the
button. As you push the button again, other codes will appear if they are there.
If there are not any the wordicon1.png 'none'
appears.
6- Record the codes.
7- To
determine if a code is current or historic, you clear the codes while being
displayed by pushing in and holding the button until 'clear' comes up. Turn off
the ignition... then crank or restart the bikeicon1.png... turn
off, and then repeat the code process. If a code is there now, its current... if
not, it was historic.
Codes
Aug 16, 2013 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
How can i make the little red engine lite go out on my 2000 nitetrain?\r\nIt only comes on some times after a long hard ride i.e.100mi@90f temp. Oil tank is full only 2600mi since change. Thanks, G.S.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
Jul 19, 2011 | 2000 Harley Davidson FXSTB Night Train
When recording disk reads repair
"REPAIR"
Because the disc was left in the unit after recording and the power plug was unplugged later, the track number and
recording time data have been cleared without being recorded on the disc.
While "REPAIR" is displayed, the track number and recording time data are repaired by tracking the recorded area. Further
recording or finalization is possible when the display returns to the previous condition. Tracking the recorded area takes about 40 minutes if the disc has been fully recorded.
Jan 29, 2011 | HHB CDR850 CD Recorder
"completed" remains on display
I solved this problem be removing the batteries briefly so that I was able to start again with a clean slate.
Dec 29, 2008 | Marantz PMD660 Digital Voice Recorder
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Panasonic RR-QR150 Digital Voice Recorder Logo
24 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
