Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Dell dimension 2400 does not see either removable disc drives .
Neither cd-rom drive or the dvd/rw. both drives have been replaced. the ones removed work fine in another PC
  • deriter Dec 02, 2008
    forgot
    forgot to mention that when i changed removeable drives i swapped cable also
    bothe drives and cable i installed in another PC they worked fine
    President:
  • 2,110 Answers
In that case ur IDE/SATA cable may have some fault...
Posted on Dec 02, 2008
The Samsung CD-Rom SC148A on my Dell Dimension 2400 won't recognize any discs that I insert. Device Manager says there's nothing wrong with it, the driver is up-to-date, troubleshooting provided nothing,...
It might be dirt on the pickup lens, and you can try cleaning it. The best way to do that is to take the drive out, remove the cover and use a cotton swab moistened with lens cleaning solution. The cleaning discs you can buy aren't usually effective. But if you're going to go through all that effort, you may as well just replace the drive. If dirt isn't the problem, the most likely cause is that the laser power has dropped too low for the discs to be read, or the pickup has failed. In that case, you'll need to replace the drive anyway. A new CD-RW/DVD-RW drive is only around $20 (or something equally inexpensive in your local currency), and it's easy to change the drive, so it's really not worth worrying about trying to repair this one.
Feb 01, 2011 | Samsung SC-148 CD-ROM Drive
What part number do i need for replacement cd rom rw dvd drive for the 2400? Thanks
Hi ,
Any one will do , you just need to know he interface used inside your machine : IDE ? Sata ?
Regards ,
Fanaudi .
Jan 18, 2011 | Dell Dimension 2400 PC Desktop
Will a Lite-On 22x DVD+/-RW Double Layer IDE DVD Burner Drive - IHAP122-04 fit in my Dell Dimension 2350 as replacement for my CD drive ?
Definitely, yes. Yes it will fit in your system without any problem. Just remove the Cd-Rom drive and install the Lite-On. If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Dell Dimension 2350 PC Desktop
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
I cannot play a DVD on my Dimension 2400. I can
Oops... Man sad but True, it isn't a DVD ROM, if it says CD-RW.
Regards,
Waqar.
Aug 17, 2009 | Dell Dimension 2400 PC Desktop
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400
Open your dell, remove the cd drive backwards, the cd driver has two green rails where it glides on. Those rails you ned to put back if you replace it with onother driver.
Good luck to you
Dec 18, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
