Question about Car Audio & Video
2001 Chevy Impala Radio - No Sound
After purchasing a used 2001 Chevy Impala, the radio stopped working after a few months. The display comes on so that I can see the radio stations and the CD player works but no sound comes out. No matter how loud I turn the volume up, there is silence. Once in a while, sound will come out and it will work fine for a day or two or even sometimes a month or two if, I am lucky.....but then it will stop out of no where. Any suggestions?
    Sergeant:
    Champion:
  • 272 Answers
Sound like you have loose connections. Start at the rear of the radio and inspect the connections. Then move to each speaker in turn and do the same. When you find any disconnected or loose connections make them good.
Posted on Dec 02, 2008
Factory radio is locked
My 2001 Chevy impala radio is lock how I unlock it
Apr 17, 2010 | 2001 Chevrolet Impala
2001 chevy impala security light keeps coming on
This is a problem with chevy vehicles that have the system theft light. after a couple of years of using the key, the lock tumblers inside the ignition switch tend to wear out and so causing the system to think it's being stolen. Now you have to put the key in and turn the ignition to the on position, without cranking the car and leave it for 10 minutes until the theft light goes out. Very annoying especially if you're in a hurry. The dealer cost to repair the ignition switch goes for about $600-$800. that includes re-teaching the key.
Feb 11, 2010 | 2001 Chevrolet Impala
2001 Impala TPMS reset, radio and headlight options DONT WORK
CHEVY IMPALA &
MONTE CARLO
On a Chevy Impala or Monte Carlo with indirect TPMS, a totally different reset procedure is required. You can use the light switch or radio to reset the system. With the light switch procedure, turn the ignition on (engine off), the turn the light switch from OFF to parking lamps three times within five seconds. With the radio technique, turn the ignition on (engine off). With the radio off, hold the DISP button until “SETTINGS” is displayed. Use the SEEK button to scroll down the menu until you see “TIRE MON.” Press the PREV or NEXT buttons until “RESET” is displayed. Then press the DISP button again. You should hear a chime and see “DONE” to indicate the TPMS system has been successfully reset. Use the SEEK button to scroll through the menu until “DONE” is shown, then press DISP once more to exit from the learn mode.
Dec 24, 2009 | 2001 Chevrolet Impala
2005 impala radio works, no sound or warning charms for low fuel.
If you purchased this vehicle used sometimes people will take the fuse out to stop the chime for low fuel and doors open. If your saying that the radio works and there is sound, this has nothing at all to do with the chime for the low fuel. Check the fuses and see if one is blown or removed. I hope this helps, good luck..
Sep 23, 2009 | 2005 Chevrolet Impala
No sound for door chimes or radio
Is the radio stock? If so have you tried getting a different OEM radio?
Jun 07, 2009 | 2004 Chevrolet Impala
2002 Chevy Malibu Radio problems
call or go to your local chevy dealer and get along side a mechanic .they know the common probs and recalls on late models.malibu and impala have alot of factory recalls on them.go on line and
search engine malibu recalls (your year)and about 500 results will pertain to your car,not year necessarily,but same car.pay attn to model year changes.i.e. like 2001-2006. same body. Gino R
Mar 22, 2009 | 2002 Chevrolet Malibu
2001 Chevy Impala won't start
If the battery has gone dead, it could cause the security system to go into full lock-up mode. If it has locked up the accessories will work after the battery is charged back up , but the power to the starter will be cut off and it wont turn over. You need to do the 30 minute learn procedure. A GM dealer will print it out for you and you can do it yourself. It's very simple if you follow the procedure exact. hope this helps and good luck.
Feb 21, 2009 | 2001 Chevrolet Impala
2001 Chevy Tahoe radio problem
Your Display will Eventually Stop alltogether. Happened on my 2000 Blazer and had to replace with Aftermarket Stereo. Dealer wanted WAY too much for new unit.
Jan 04, 2009 | 2001 Chevrolet Tahoe
Unloking radio for impala 2000
I switched my stock radio out of my 2001 Chevy Impala because it was defective and replaced it with a used radio I got from the junkyard. I called Chevy to see if I could get the code to unlock it and they told me I had to go to a Chevy dealership which I did. Cost $40.
Oct 28, 2008 | 2005 Chevrolet Impala
Car Audio & Video Logo
1,295 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
