The visible fan at the top of my tower appears not to be running. Also computer makes a lot of noise and several times when I have turned it on it shuts down. There appears to be a lot of dust on the fan blades. Would a can of forced air help
    Scholar:
  • 160 Answers
The air may help, but it may be the power supply fan may be bad. excess heat is the probable cause for the shut down. when using air, do not allow the fan blades to spin by holding them in place while blowing them. also open the case and do the same for the inside of the case and all cards and fans, especially the cpu fan.
Posted on Dec 02, 2008
    Master:
  • 474 Answers
Yes, it can help, have the machine off before spraying.
They Fan may have dust build up all around the blades and in the little motor. while the comp is on, try pushing the fan with a pencil or your finger, if it trys to turn on its own, then its still good and just needs to be cleaned. If it doesnt, then it probably burnt out.
Replacement are around5 to 10 dollars depending.
It easy to do and better than overheating your system, which is what is happening when it shuts down. If the fans are making alot of noise, its do to dust in the bearings and they will probably fail eventually, so be prepared to change those as well.
Take them out and with you to the store so you can match them up and get the right ones. The ones with lights are cool and make it easy to see if they stop spinning.
I would clean out the whole computer with compressed air and remove as much dust from the fans and the processor heat sink as possible.
Remove the side panel and take outside and blow out the air. Hold your breath when you do this as skin cells and hair makes you cough and gag when you breath it.
You should always check at least once a month for dust buildup and clean as necessary. Dust is the leading cause of overheating and eventual system failure.
Good luck
  • 25 Answers
. You could try air but if the fan does not work the computer overheats and shuts down to protect itself.
The air won't hurt, but more likely you have a bad fan which is going to require either you or someone to open the cover, go into the computer, remove the fan, buy a new one and put it back in.
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
Acer m5100 desktop fan is making noise
Hi:
Often, just dust can make fans noisy. You can unplug everything, take the side cover off of your tower, and blow it out with a can of the air duster you can buy at a computer store, paying close attention to the fans. If you are not comfortable with this, a local shop should be able to clean it up for you for not a lot of cash, and if a fan is really bad, they could identify which one it is for you too.
Oct 26, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Fridge makes chirping noise
Some areas noise may come from:
Inside:
Whenever the refrigerator is cooling a circulating fan is operating to move air through the freezer and refrigerator. This fan can be found in one of several locations: For freezers positioned on top of the refrigerator the fan can be found on the back wall at the center of the freezer; If your freezer is on the bottom then the fan will be near the top on the back wall of the freezer; and if your freezer is on the side the fan will be on the back about 1/2 way up or near the top.
These fan tend to wear out over time and make a noise like a whistle or chirping sound. Open the freezer and press any switch. If the noise is louder with the door open the motor that operates the evaporator fan is likely the cause. This fan cannot be serviced in any way and must be replaced.
The back of the refrigerator:
The compressor, defrost timer, or the condenser fan motor may be the cause of noise from the back. The compressor is located near the bottom and is identified by it's small black case that appears to have no moving parts, but several colored wires coming out of it. If you find the compressor is what is making the noise then you will have to replace it in order to get the noise to stop, these aren't serviceable (and can be expensive). Near the back of the refrigerator you'll also find the condenser fan. Sometimes this fan gets clogged with debris and can make a lot of noise as a result. If this is the case then simply clean the blade with a soft bristled brush, you can usually get one of these brushes from a hardware store, or you can order it from us by calling our 800 number. If it doesn't need to be cleaned then the whole motor may need to be replaced.
The defrost timer is usually found behind the kick panel. The timer has an electric motor attached to it that may become noisy over time and will need to be replaced in order to get it to be quiet again.
The bottom of the refrigerator:
Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Sep 21, 2009 | Refrigerators
The fan is making a lot of noise. this has
Is the laptop dirty inside?
If it hasn't been cleaned out regularly, with a can of compressed air for computers, more than likely it is.
Laptops typically have a poor cooling design. For one, everything is crammed into a tiny box.
For two, there is a small duct, (Air Intake Duct), that draws air in.
For three, laptops typically just have 1 small fan.
For four, the Air Intake Duct is located on the bottom of a laptop, or on the side.
This is an excellent (?) area to draw foreign debris in. Another word for foreign debris, would be CRUD.
Hair, Food Crumbs, Lint, Dirt, Dust, and so on.
A laptop's cooling systems primary function is to keep the Processor at a certain temperature. If the processor becomes too HOT, it turns off. (BIOS turns it off)
NO Processor, No computer!
1.The excessive fan noise can be that the fan is spinning at top rate, trying to keep the processor cool. It's having a hard time doing that, because the fan cannot draw enough air in. (Clogged Cooling System with Crud)
2.The excessive fan noise could be that the fan's bearings are bad.
3.The excessive fan noise could be that the Processor is running at 100 percent, (100%), and the fan is running at full speed, in order to keep the processor cool.
Perhaps caused by a virus, or some sort of anti-virus program, or running more than one virus program. (Installed a new anti-virus program lately?)
Aug 04, 2009 | Computers & Internet
I have fan failure. It has been making a strange
This is probably because the fan has most likely 'died'. I would replace the fan because you don't what your computer to start to freeze up, overheat etc...
Jul 10, 2009 | Dell XPS 200 PC Desktop
Tower fan runs fast without stopping
either your computer is running too hot (clean it out physically, or clean out viruses) OR the fan is failing, and it sounds louder and faster cause the bad fan bearings are making that noise.
Mar 12, 2009 | Computers & Internet
Fan/ engine whining sound
If the fan is only making wind noise it is ok. If it is making matalic noise replace fan. It would be a good idea to clean (blow)out the dust and dirt for the inside of the computer at this time.
Jan 12, 2009 | Computers & Internet
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Fan runs all the time
I HAVE HAD A COUPLE OF UNITS THAT HAVE KEPT THE FAN RUNNING ALL THE TIME. I REPLACED THE CONTROL AND THAT TOOK CARE OF THE PROBLEM.
Mar 09, 2008 | Whirlpool AD70USS Dehumidifier
Fan noise
Generally fans on lower end cases are fairly cheap. I've had several new ones that make lots of noise new. You can call the manufacturers tech support and mess around tryig to get a replacemet or you can just order an inexpensive replacement fan. Cyberguys is where I typically buy my replacements. http://www.cyberguys.com/templates/searchproducts.asp?categoryID=191
Sep 18, 2006 | Vtech 8870KL ATX Mid-Tower PC Micro ATX...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
