Only connects to the internet wired connection wireless not working now
Check that if there is Static ip configured on your Lan-Card...
if yes.. then you need to configure the IP addresses manually for W-LAN as well.
One more thing; if Lan-card is not configured with static IP then
make sure your W-lan IP seting is on "obtain Ip automatically"
Here is the way to do this....
Click on the start orb to open a list of programs and content. The
start menu has been replaced by the “start orb” which still gives you
the same functionality as the start button from previous OS versions,
but consumes less screen real estate.
Right click on “Network” and go to properties. That opens the
“Network and Sharing Center” which is your central office for anything
pertaining to (just as it says) networking or sharing resources.
On the left hand column you want to click on “Manage Network Connections.”
This opens the Network Connections Window which you will find
familiar to Windows 2000/XP. It will list all of your NICs or Wireless
Connections.
Right click and go to properties of the connection you would like to
statically assign. You will now be prompted for an administrative
password. This is part of Microsoft’s new User Account Control (UAC)
which will help unauthorized changes to your systems.
Once you have authenticated you will see the properties of the selected network connection.
The properties screen is very similar to what you’ve seen in the
past, but one thing you will likely notice is by default Windows Vista
supports IPv6. If you’re on a corporate or government network that is
running IPv6 you can fill in your IP information there.
Otherwise, you will select Internet Protocol Version 4 (IPv4) and click properties. Now you will be able to Choose the option "Obtain Ip adress automaticlay"
Close the Network Connections Window
Let me know if this helps.. Good luck...
regards,
Ok. As per your statement your laptop is working
perfectly , when you are connected your laptop with with the cable wire.So the
network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After
connecting the cable wire to your laptop you have to findout the gate way of
your ISP ( Internet Service Provider). To find out the gate way , kindly follow
the following instructions.
First findout the IP address , subnet
mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out
the above mentionedaddresses first open the control
panel -> network connections -> local
area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet
Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP
address, subnet mask and Gateway addresses. Kindly note the Gate way address of
your ISP. Then enter the gateway address in the browser and open the window. Then
a control panel / a window will appear. It will prompt you to enter 1). user
name, and 2) password. If you are having the user name and passwords provided
by your ISP , kindly enter them in the window and click to open. Then the
particulars of your ISP will be displayed in the window. Then click the wireless
icon and click to enable. Hurray ! your laptop will work perfectly through
wireless. If you are not aware of about the 1). User name and 2). password ,
you must approached to your ISP and try obtain the same for working of your
laptop wirelessly. Provided , that you have to configure the wireless enabling for both the ethernet cables and there after save the changes , after finding the 'GATEWAYS' if both the the ISP's seperately.
particulars of Motorola SURFboard SBG900
Wireless Router will be displayed in the window. Then click the wireless
laptop wirelessly.
VISTA ,IT IS NOT DISABLED
Gateway MX6426 Lost Internet and says TCP/ip Not enabled.
Any ideas.
Both my wireless and ethernet connections do not work. This occured after a power surge. Could it be possible that both connectors were fried or could they have lost their driver information?
Kindly check if the wireless conection is not disable...
which OS you are useing?
laptop wireless access won't connect to internet
