Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune tl wont empty stuck on 11 and shows nd i blow in to the d
I blow in to the drain tude feels blocked
    Genius:
  • 1,199 Answers
Water pump may be broke! does it make a funny noise?
Posted on Dec 09, 2008
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
my he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Oct 26, 2013 | Maytag Neptune FAV6800AW Top Load Washer
How do I access the Stand Pipe of a Fav-1 Neptune top load washer to unblock whatever is in it? Trouble Code nd. It looks like I access it from the front but I don't want to break something by trying to...
Yea it a PITA for working on anything to do with the Drain Pump/Pressure Switch
Do you have the front cover off?
Front Cover access is it.
Do you have standing water in the Tub? If not the ND error code for No Drain may be false.
If you Power Cycle the machine will it clear the ND error code? If so put couple of gallons of water in the machine then (if you don't know how to turn the Drain Pump on in service mode) start a Spin Only cycle and observe the discharge line at the sink or bucket. It should empty less than 20 seconds.
If it does then the Pressure Switch contacts are stuck closed.
I'll post a pic of the Outer Tub removed while I was doing a Outer Tub Bearing job on my machine.
If you need additional help go to a real DIY forum. Google this; Neptune TL Washer FAV6800AWW
5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don't want to waste my time in this forum. If you need additional help to troubleshoot the ND error code re-post in that forum.........D*ickfav6800awdiy_1.jpg
A shot with the front cover off looking into the drain pump/pressure switch. Look like fun right.
In this post Clutch Fix the first couple steps will help you get the front cover off. See ya on the other forum if you need additional help.
Feb 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
ND error, pump runs, but sounds rough, took pump apart and found nothing in the pump or pipe.
If the motor is running but there is no water coming through, it would suggest the pump impellor blades are compromised. It's quite posible that the shaft that drives the blades has snapped. Is it possible to open the pump housing and rotate the blades manually whilst watching the motor to see if it moves? If one moves without the other, then its a new pump I'm afraid. WARNING! Do NOT attempt to do this with the motor connected to the electricity supply.
Feb 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Has 33 minutes and a error message of nd--maytag Neptune tl
What is the Model number of your machine if its a FAV6800A or FAV9800A please read on.
The ND error code means No Drain.
You could have a drain line clog or a stuck Pressure Switch contacts.
See this post for past troubleshooting;
http://www.fixya.com/support/t2209123-code_nd_fav6800aww_serial_number_10
There are links to the Service Manual and I go over how to put the machine in Service Mode to check that the Pressure Switch is signaling properly.
Do you want to DIY the repair?
Let me know.........Rich
May 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does "nd" mean on my neptune washer
Hello tana_carney4,
Your in the FAV6800AW forum so I’ll assume your machine type is a FAV6800AW or FAV9800AW. I’m an owner of the FAV6800AW with some hands on experience with the machine.
The ND error code equals No Drain. The microprocessor on the Control Board keeps track of the time needed to receive a Low/Mid Level fill indication from the pressure switch at the start of a tub drain cycle. If that time elapses and the pressure switch is signaling that the tub has watering remaining then you trigger the ND error code. Is the tub empty or is there standing water in the tub with the ND error code?
If the wash tub is empty and you fail out of the wash cycle with the ND error code then I feel you have pressure switch failure, the pressure switch is signaling the Control Board incorrectly. We need to go into Service Mode “Board Input Test “ and check if the pressure switch is signaling a -1 with an empty tub (no water). If rhe pressure is signaling a -1 with an empty tub then the pressure switch is false signaling “Stuck Pressure Switch” you will error out in the wash cycle with the ND error code and the Pressure Switch will have to be replaced.
If the wash tub has standing water in the tub with a ND error code to the console we need to check for a failed drain motor, a drain pump impeller jam/clog. We would go into Service Mode turn the drain pump and listen. Do we hear the drain pump turn on? If so will it pump out 5 gallons of water in about 25 seconds or less as my working FAV6800AW will do? Further troubleshooting will require a DVM to verify that 120VAC is applied to the drain pump, If we have 120VAC at the drain pump motor connections and we don’t hear it turn on we would need to remove the drain pump and check for failed motor or jammed impeller. If the drain pump turns on but we have slow drain out of the drain pump we could would need to remove the drain line from the Sump Cap to the inlet of the drain pump and check for restrictions and possible impeller damage to the drain pump.
The question is do you just want know what the ND error code is?
Do you want to DIY the repair? If not then it would be time to call in a repair service.
Here is the FAV6800A/ FAV9800A Service Manual link.
If your machine type is not a FAV6800AW or FAV9800AW then please disregard my post.
Rich aka dh1200s
Nov 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Neptune
Check your control board out .look for a burnt R-11
Mar 31, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
