Question about Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive
Error code Ox8007065D
I have a Verbatim portablehard drive usb @.0 250GB and when I try to back up (shadow copy) it seems to start OK, but after a few moments error code Ox8007065D come up with "data supplied is of wrong type". I have no idea what this means. Can someone help please?
  • 20 Answers
Http://mb.music.yahoo.com/music/Support/threadview?m=te&bn=mus-ymefeedback&tid=2440&mid=-1&tof=8&rt=2&frt=2&off=1
Posted on Apr 02, 2009
USB port is not recognized in any of my computers or in any port.
It seems that the issue is related with the flash drive itself, I have came across with such problems many times. I guess now it's time you should go and ask for a replacement.Most of the flash drives comes with 5 years warranty. You may want to call verbatim customer support for warranty. Contact details
http://www.verbatim.com.sg/en_SG/contact-us
Feb 07, 2014 | Verbatim ® Store `n` Go USB Flash Drive,...
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I dropped 500gb verbatim external drive. It wants me to format the drive. How can i get the data back before i format it? Please help Thank you
Because the first few records stored on the disk-drive have been corrupted (or are physically unreadable), you get the "please format" message. Hopefully, the other 99.9 percent of the data-blocks stored on the disk-drive are OK.
Search online for 'data recovery' software -- it reads through the disk-drive, block-by-block, trying to merge blocks of data back into files that can be copied onto your 'C:' drive.
Sep 17, 2010 | Verbatim External, USB 2.0, 750GB...
I have a verbatim 8GB USB Flash Drive, Store 'N Go. It just stopped working, no lights, nothing. The metal that comes out is loose and shaky. How can you open this thing? Would opening it up to see if a...
Ok.... listen up dude.... first of all USB drives has no wires in it to check if the wire inside has got loose or not it has only chipset inside so there occurs a problem then its with chip only :) recovering can be done if u give it to a expert and tat too there is no guarantee on recovery :)
Jul 25, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Corrupt file system
In Windows Explorer, right-click on the drive and select Properties from the context menu. Select the Tools tab. Click on the Check Now button in the Error-checking box. It will probably respond with a UAC prompt, so enter a username that has administrator access and its password or select the Continue button as required. If the chkdsk utility cannot establish exclusive control over the drive you may need to schedule the check to run after the next reboot, then reboot the machine. It will run a comprehensive check of all of the structures on the drive and fix any errors it encounters. Once it is done, you should be able to backup the drive.
Apr 10, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Cannot copy DSC02049: The path is too deep. Error message appears. The file is less than 1MB in size. This message appears even when copying from the root directories. It has 490MB available memory. The...
It seems all USB ports are not equal. Of the ports available, the ones on one side of the computer seem better than the ones on the other side. Changing to a different port solved the problem. There have been no data transfer issues since the change.
Oct 02, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim 1gb flash drive privacy zone lost space
In order to delete your privacy zone, you have to get the application once more. To get the software click here http://verbatim.com/support/support.cfm?open=Downloads ...ok so you will have to format your flash drive with the application, removing the privacy zone if you want, this will obiously DELETE ALL DATA ON THE DRIVE after the format has completed, you can then remove the application from you flash drive, if you still remember the privacy zone password, then all you have to do is just type it and you have acess to the privacy zone... anyone who needs assistance can contact me to semirandomjr@yahoo.com if you are confused, email me and i can also try to clear it up for you. MAKE SURE THAT YOU CHOOSE THE CORRECT PRIVACY ZONE APPLICATION FOR YOUR FLASHDRIVE
Feb 26, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
How do I turn off the write protect on the verbatim 4gb flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 17, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive Logo
252 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
