Question about Mitsubishi VS-55707 TV
Set will not stay on
Set turns on after pushing power button 1-to-7 times pictures fine than after a couple of minutes picture starts to scramble and shuts down.
  • don walker Jan 31, 2007
    After reading some solutions for other problems
    I opened front & back access panels and used a
    compressure to blow the dust off everything.
    The set had been unpluged for about 24 hours,
    I plugged in the set,turned on so far so good, set stayed on till I shut it off 4 hours later.
    Sergeant:
  • 308 Answers
Better get this checked out by a technican. One possible reason could be coolant from the picture tubes leaking down onto the printed circuit board causing this symptom which could end up destroying the circuit traces on that board. Other possibilities include problems in the power supply or deflection circuits. If the set is over 8 years old, I would just replace it with a HDTV.
Posted on Jan 30, 2007
Power won't stay on
did you ever get this fixed mine does the same thing,replaced the caps in the power supply but still won't work
Apr 06, 2009 | RCA Televison & Video
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
W2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
Aug 19, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
TP50G60 bad scrambled picture - shuts off after 1 minute
This does not sound to me like a convergence roblem. It could be a shorted picture tube. That would put the set in a shutdown condition. Normally in Toshibas , the picture remains on with a convergence problem. Here is something you can try, but you must be very careful. Remove one crt board at a time from all three tubes. if the set stays on after one of the crt board are removed , then that is the shorted picture tube.I cannot caution you on how care full you have to be trying this procedure. Scrivitron
Jun 29, 2007 | Toshiba TP50G60 50" Rear Projection...
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Mitsubishi VS-55707 TV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
