Question about Breville CT20 Retro Classic 2-Slice Toaster
Removing bottom cover to access fuse etc - toaster not working
The screws at the bottom of toaster are not conventional. Where can I get a screwdriver?
Wiha Tools. Order M2.3 spanner, item 30523.
Posted on Aug 17, 2012
    Problem Solver:
  • 10 Answers
Hi.. the screws on mine are pozidrive (plus sign shaped slots).. what do yours look like?
What's your toaster problem?
Posted on Dec 19, 2008
INSTRUCTION to dismantle toaster
Hi benbecula. I cannot find a repair manual for you. The normal way top dismantle a toaster is to remove the screws beneath the toaster. They are usually self tapping screws that hold the polished stainless steel cover to the base. The knobs on the front of the toaster have to be prised off so the cover comes off. Make sure the toaster is removed from the power before attempting and examination or repair.
Hope this helps,
Michael
Jun 04, 2014 | Russell Hobbs 13767 4Slice Toaster
How do I remove knob from Magimix 2-Slice Vision Toaster with out damaging it?
Do not try to just pull it off, you will likely damage difficult to repair parts.
On the underside remove 6 pozidrive screws 3 each end (one under the crumb tray)
Standing on its base - open the doors and remove 4x countersunk torx T10 screws, near the top, that screw from the inside into the end covers.
Now remove the opposite end to the knob, (in order to learn how it is held). Pull the bottom away from the base to the left, around 5 mm, and slide the whole end cover upwards, it unclips at the top. The other end is not so easy of course because of the knob. Release the cover, as before. It is possible - with the knob at the top, pull the bottom of the cover out 5mm and push hard to slide it upwards as before. The cover will release from its top mount. Then slide the cover all the way up, as far as the knob slot will allow. This will allow you see and have access to the back of the knob and the plastic clip that holds it in place. Stand the toaster on its base, with the end cover lifted up it is easy to put your hand inside the cover from the top and putting your thumb and forefinger around the bar you can grip the plastic hook and ease it downwards whilst you use your other hand to pull the knob and its firmly attached bar away. It will be necessary to wiggle the knob up and down whilst pulling it outwards. The bar surface is not flat, it has ridges that hold it in place quite well, even without the clip, hence the need to work it up and down. That's all there is to it! Hopefully you haven't broken the clip off, but if you have, don't worry you will still be able to use the toaster with little impact. The attached photo shows a close up of the knob and bar just separated from the mechanism. This should give an idea of what you are up against.
What a fantastically well made machine this is, a real pleasure to work on.
Oct 07, 2013 | Magimix 11535 Toaster
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
4 slice toaster when pressed down to start toaster they won't stay down.(either side) Yes I have it plugged in
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Jan 06, 2011 | DeLonghi RT400 Retro 4-Slice Toaster
Back to Basics TEM-500 toaster no longer heats up
We have the same problem after only about 20 uses. The customer service number is 1-800-688-1989...we may be able to get it replaced. If they aren't willing to do anything, I'm thinking of filing a complaint with our state Attorney General because there are SO MANY complaints of the SAME, idential problem from thousands of consumers!!!!
Jan 02, 2010 | Back to Basics TEM-500 Egg & Muffin...
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
Fan works timer works but no heat
There is no fuse. Take back cover off and all bottom perimeter screws. Outside cover pulls off towards rear once you get all the ** little screws out. Chances are you will find burned connections on the heating elements poking out the sides of the heating chamber. Try cleaning these and squeeze them tighter before reconnecting. Good luck!
Oct 22, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Breville CT20 Retro Classic 2-Slice Toaster Logo
468 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
