Question about TruTech PLV16320 Television
TV won't turn on
I have seen this problem posted before.  The red light comes on but when the power button is pushed the light goes out and nothing happens.  I am assuming that it is the capacitors on the power supply that are bad.  Someone else mentioned that the bad caps will be bulged out on the top but I am staring at the power supply and all of the caps look fine.  The large 450v 150uF cap has a very slightly rounded top but I don't know if that is normal.  If anyone knows that this is a power supply problem for sure and if the capacitors could still be bad please let me know.  Thanks in advance!
  • 2,323 Answers
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Posted on Dec 02, 2008
Tv won't come on
The set is in Shutdown---27 inch may not be worth the cost of repair
Apr 30, 2012 | Samsung TXS2782H TV
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
My projection tv trys to come on but won't you push the button and the power on light comes on but goes off comes back on then goes back off 3 to 4 times then goes off for good started few days ago but if...
I need the model number of your set. And can you count exactly how many blinks the power light blinks when you press power? Please respond to this same post so all comunication will be available for each response.
Jun 26, 2008 | Televison & Video
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
TruTech PLV16320 Television Logo
149 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
