Question about HP Photosmart R707 Digital Camera
Flash does not work
Does anyone know how to get the flash to work? Does anyone know how to replace the flash component. Also, the mode button, which is on the flash board, does not work.
  • Amandio Rua Dec 02, 2008
    Have you removed the flash circuit?
  • Amandio Rua Dec 03, 2008
    Are there instructions that I can refer to properly repair the camera without damaging any other component?
  • 477 Answers
The flash circuit has a 330 volt compositor and if you are not careful it can shock the crud out of you believe me its not to fun. repairs can run from 40.00 and up depending on where you get it fixed.
Posted on Dec 02, 2008
  • Mike Johnson
    Mike Johnson Dec 02, 2008
    Yes I repair these cameras all the time. some times it is easier to remove the main board first.To get the compasitor out.
Hello, I have a 04 Jag X-type. Anyone know how to
PRESS MODE UNTIL CLOCK 12H OR 24H FLASHES THEN CHOOSE BY PRESSING LEFT BUTTON OR RIGHT THEN TYPE IN THE TIME LIKE A COMPUTER
Jun 01, 2010 | 2004 Jaguar X-Type
My flash on the kidizoom camera won't work
To Change your flash settings, press the Delete Button while in Photo mode until desire setting. I had the same problem!
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf (Page 9)
Jan 15, 2009 | Vtech Kidizoom Digital Camera
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Sony Cybershot DSC-H7 - can not change flash settings
for anyone who wants to know how i solved my problem with the flash saying it cannot be changed...
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
Mar 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash Settings Only Work When in Night Mode
Hope this helps it got mine working
leave lens cap on in night mode then start up flash & take a shot,
press the flash key symbol button & you should see changes on the screen monitor, then go to auto mode to take a shot with flash make sure AF is not on.
Sorry it is a bit vague but this got mine working again.
Dec 13, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Disabling Auto Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Nov 21, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Flash button won't select mode.
you cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
Sep 03, 2007 | Fuji FinePix S5000 Digital Camera
Switch Off Pre-Flash
Hold down the flash button and turn either wheel. Select a flash mode that doesn't have the "eye" (red-eye reduction) symbol visable on the display.
Sep 13, 2005 | Olympus Camedia E-10 Digital Camera
HP Photosmart R707 Digital Camera Logo
85 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
