Computer external hard drive problem
Please offer advice if you can.my job is seriously on the line. My Lacie D2 external hard drive power failed today while in use on a Mac powerbook G4 using pro-tools music software.The drive has always made a slight quiet ticking noise while recording to and playing back from it, it was no different from normal when the problem occurred. I foolishly had not backed up some very important recordings before it died on me. The power cable has a Green LED on constantly when its not plugged into the drive, however when i plug it back in it dims in brightness and flashes on and off so i dont think it is the power supply. The drive will not switch back on.Is this easily and cheaply repaired or can I sowehow swap the drive into another identical model.Please please has anyone any expierrince with this.
    Problem Solver:
  • 19 Answers
If the hard drive still spins, then the data can be saved. If there is a near by computer store, explain your problem, and they can take apart the drive and probably but the data on a new drive for you. If you want to try this yourself, you will need to take apart the outer enclosure of the Lacie drive. Then unplug the hard drive, and either put it in another similar enclosure (requires taking that one apart too) or buying a new enclosure.
Regards,
Sam
Was this information helpful? Please rate it!
Posted on Dec 02, 2008
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Please offer advice if you can.my job is seriously on the line. My Lacie D2 external hard drive power failed today while in use on a Mac using pro-tools music software I foolishly had not backed up some...
You don't mention if there is any clicking coming from the drive - so I'll suggest this...
Crack open the enclosure and remove the drive (this will void your warranty,) find matching I/O and PWR cables and just connect the drive to your Mac. If you hear clicking - then your dive is mucked up. If you can READ from the drive, the enclosure has an issue and should be addressed to the manufacturer for replacement.
Dec 02, 2008 | Computers & Internet
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie d2 external drive
you may need to get a new driver for that lacie from their website..
support downloads, model o/s
Mar 01, 2008 | Computers & Internet
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
http://homepage.ntlworld.com/allcam/pc2mac.html
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
