Question about Xante Accel-a-Writer Laser Printer
Prints come out grey with toner
Hi, We have a Xante Accel-a-Writer 3G here that is printing out grey paper, the toner is all over. I cleaned out the transfer roller various times. Could this be a humidity issue? Bad Toner cartridge? Any ideas? Thanks, Chris
Xante 3G - indicates 'print' then constant 'front paper jam' (any size)
That is cause the paper feeder is not working properly. It could cause the roller that feed the paper wear out or a bad tray release selenoid
Jun 12, 2014 | Xante Accel-a-Writer 3N Laser Printer
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
Is there a driver for Windows 7 for Xanta 3G
check it at Xanta accel a writer 3G lasr Print homepage
Dec 03, 2010 | Xante Accel-a-Writer Laser Printer
I need a new toner cartridge for my Accel-a-Writer3 G. Where do I find one and how much does it cost
Try superwarehouse.com
or Xante in Mobile, AL (xante.com)
or some of the paper suppliers that supply commercial and local printers might also carry the toner.
May 11, 2010 | Xante Accel-a-Writer Laser Printer
We are getting black lines/residue through the center of every print we do. Toner is only 2 months old. How can we illiminate this problem?
Your corona wire needs cleaned. Be gentle with it ... use a que tip. Make sure the entire paper path is clean up to and including the fuser.
Thanks for your question at FixYa.com
Feb 19, 2010 | Xante Accel-a-Writer Laser Printer
Wrinkling Laser Paper
Sounds like something is either wrong with the rollers, something is stuck in there or you are using the wrong type of paper.
I suggest you take a peek inside there and see if there is anything noticeably wrong inside. If not then look up what type of paper it needs.
Jul 10, 2009 | Xante Accel-a-Writer 3N Laser Printer
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Apr 17, 2009 | Xante Accel-a-Writer 3N Laser Printer
Accel-a-writer 3g for leopard
Yes. If you need the driver here is the link. Just scroll down to operating system and choose Mac OS X. If this takes care of your problem please rate as fixed. Thanks.
http://www.xante.com/support/aw3g/
Apr 03, 2008 | Xante Accel-a-Writer Laser Printer
Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Jun 19, 2007 | Xante Accel-a-Writer Laser Printer
Xante Accel-a-Writer Laser Printer Logo
195 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
