Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Driver's door won't unlock with remote
I have a Viper 791XV on my vehicle. When I have the vehicle locked and alarm engaged, if I try to disarm alarm/unlock doors using the remote, all of the doors unlock except the driver's side door. When I use the button on the door inside the vehicle to lock/unlock, the driver's door works fine.
  • 2 more comments
  • Anonymous Mar 19, 2014
    When I lock the doors on my 2003 Honda Pilot the alarm system will not engage.
    The door lock but the alarm system does not engage on my 2003 Honda Pilot
  • Anonymous Mar 20, 2014
    after reprogramming my new replacement remote the only way I can lock or unlock my vehicle is with the remote. the lock button on the vehicle does not activate the locks nor does the mirror adjustment control for the outside rear view mirror work. My vehicle is a 2000 GMC Envoy. Also my tail gait opens two ways, you can either lift the entire tailgate or just open the window part of the tail gate. I can't open the glass portion but can lift the whole tail gate.
  • Anonymous Mar 21, 2014
    I just purchased a used miata which come with a Viper 488v alarm. When i press "lock", it won't lock. When i press "unlock", it lock. Remote Start working when i press "lock" & "unlock". "*" is working too.. And it doesn't have any sound at all. Just wondering what's happen how to lock my vehicle?
    Problem Solver:
  • 13 Answers
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Posted on Dec 04, 2008
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
2011 nissan sentra s door lock actuator wiring diagram
From the plug in door lock harness of the Viper alarm (green and blue): the green lock wire goes to the red wire of the vehicle in the driver kick panel and the blue wire goes to the pink wire in the kick panel. The light green with black wire from the Viper alarm goes to the white wire in the drivers kick panel. This white wire is the factory alarm disarm wire. It tests with the key in the door cylinder. Turn the key to unlock the door and the wire should register ground.
Aug 01, 2012 | Viper Vehicle Parts & Accessories
Viper remote won't open door lcks
Does the remote diarm the alarm? Do you hear the " chirp chirp" when you press the unlock button on the remote? If not, then the remote is defective or needs to be reprogrammed to the alarm. If you do hear the " chirp chirp" but, the doors do not unlock, then the issue is with either the wiring from the alarm or the vehicles power locks. Did it work before? Do you have power door locks?
Jul 21, 2012 | Remote Start System
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The car itself does not beep when the alarm is armed or disarmed
An output wire is not connected, you'll need to connect the brown wire on the 12 pin harness to the siren, it will be pin number 10. Either that or your siren is bad.
Oct 08, 2009 | 791XV The 791XV is a 2-way Security and...
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
596 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
