Question about Konica Minolta Magicolor 2530 DL Laser Printer
Drum unit setting
I need to adjust the setting for the drum unit. The factory setting ensures that it stops after a certain number of impressions, and I want to be able to make the judgement myself as to when it needs replacing.
It is actually a 2550, not a 2530 but I could not find that listed.
Replace small fuse located on drum.
Posted on Jan 27, 2009
    Problem Solver:
  • 5 Answers
I put in a new drum, but then thought why not use the old drum until I have problems? (Is this a mistake, am I causing unnecessary wear and tear on the printer?) When I put in the old drum the printer still thinks it's the new one, so I've got full life again.
Posted on Mar 25, 2009
No drum replace & developed replace how to sole konica minolta bizhub 206 error code m2 reset
did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 206 maintainance service m2 how to set this problem
Did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
After replacing drum and developer unit, printing output is too light and unable to be adjusted. I've set the image to -3 and the grid to +2 but the printing output is still too light and on the density...
first did you clear the counter for the drum and developer before replacing them second did you run the required F 8 procedure if not need to buy new drum and developer. Start over the counters are cleared in service mode then you take the image unit out, then replace the drum and developer then re-install the image unit then run the the required F 8. ENSURE FAX LINE AND NETWORK cables are removed do not want a fax or print job to come in before running the f 8.
Jan 30, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
COF32 KONICA MINOLTA DI2510F
Does the control panel say replace PC drum? Then replace the drum and developer both are replaced at the same time. If that does not work replace the ATDC sensor located under the image unit. has multi color ribbon cable. If not that then the main control board if you can find one. Best bet would be replace the developer and ensure you clear the counter for develop and run the F8 process after replacing the developer. DO NOT USE A VACCUM CLEANER to replace the developer because the static electricity from the vacuum cleaner can destroy the sensor. Also the copier uses the counters to adjust voltages for certain assy. so if you replace the developer and don't clear the counters then the machine will adjust voltages for a used drum or developer when in reality the developer or the drum are new. Causing image problems and codes
Aug 21, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Bizhub Konica Minolta - Error Code C2257
Replace the developer. If that does not work replace the ATDC sensor located under the image unit. Has multi-color ribbon cable. If not that then the main control board. Best bet would be replace the developer and ensure you clear the counter for develop and run the F8 process after replacing the developer. DO NOT USE A VACCUM CLEANER to replace the developer because the static electricity from the vacuum cleaner can destroy the sensor. Also the copier uses the counters to adjust voltages for certain assy. so if you replace the developer and don't clear the counters then the machine will adjust voltages for a used drum or developer when in reality the developer or the drum are new. Causing image problems and codes such as 2257. Also recommend the drum and cleaning blade be replaced, does the control panel in the upper left say replace the PC drum?
Try this site for the parts:
T
Try this site for the partsT Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 07, 2012 | Minolta bizhub 200 All-In-One Printer
Drum full of waste toner. Do i have to replace the
I have no idea what ikkenom is smoking.
The Drum Cartridge unit is as user-replaceable as a toner cartridge.
Yes, you will have to replace the drum cart.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=bsdv&sku=310-5732
Dell wants $169 for this part. Here's what it does:
Highlights
* Applies toner to the page
* Provides a usable life of up to 42,000 page impressions (up to 10,500 pages per color)
Overview The Imaging Drum Kit from Dell is specifically designed for use with Dell Color Laser Printer. This kit includes an imaging drum and instructions on how to replace it. It applies toner to the page and offers a usable life of up to 42,000 page impressions (up to 10,500 pages per color).The part number located on this toner cartridge is: P4866
Manufacturer Part# : M5065
Dell Part# : 310-5732
It comes with very detailed instructions on how to remove the old cartridge and install the new one. Very easy, but there's no way around the price tag.
Nov 18, 2009 | Dell 3100cn Laser Printer
Have a Magicolor 2430 DL. Getting message "drum low". Does this mean I have to replace the imaging drum or something else?
Most all replaceable parts on MagiColor printers are literally scheduled to be replaced after a certain number of pages printed using them. Officially, this is to ensure print quality remains sufficient. Unofficially, it's just another way to **** money from your wallet.
That being said, there is likely a fuse somewhere on the OPC drum unit that, when replaced, will reset the page count for that unit. Once the page count is reset, the fuse is blown, and counting resumes.
Examine the unit for large, silver, metal contacts. The fuse will be underneath those (or very nearby). Either replace the fuse or temporarily short the contacts. If you short the contacts, turn the printer on, verify the printer "thinks" the drum unit has been replaced, turn back off, and remove the short circuit.
Jul 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Canon NP 6030 dark copies
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Oct 23, 2007 | Canon imageRUNNER 5020 Copier
Konica Minolta Magicolor 2530 DL Laser Printer Logo
171 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
