Question about HP Photosmart M517 Digital Camera
Lens will not open with batteries
This is a weird problem. On my m517 camera, I inserted a fresh set of re-charged batteries and turn the camera. The lens will not extend out and all I see is black. However, when I connect the camera to AC power, the lens open and the camera is fully functional.
  • HP Master
  • 19,396 Answers
Try cleaning the battery contact inside the camera batteries slot.
Also test a different battery, possibly a battery pack that you tried on a different camera.
If that does not fix the problem, then there is a faulty component iside the camera, usually you get this kind of problem because of a faulty camera, or oxide on camera batteries contacts.
Posted on Dec 02, 2008
I have a problem with the Samsung S600, when you turn on the digital camera everything is blurred, if it includes an option or something else. Please help
Your camera lens is not its own correct position. But before deciding you should do the followings.
1. Turn off the camera.
2. Remove batteries and memory card.
3. Charge your batteries fully.If you have another fresh charged battery then change them.
4. Place memory card and new batteries.
5. Turn on your camera.
6. Enter settings and turn your camera settings to fabrical settings. I mean reset your camera.
7. If the problem persists then this means that your camera lens is not its original position.
8. May be you have touched your lens or dropped your camera or something else.
9. Please turn on camera and pull and push your lens gently. Be carefull not to force it.
10. If nothing changed then this means that your camera must be opened by an authorized service repairman.
11. Shake your camera if there is a broken parts noise. If there is a broken part in it then this means, lens and related parts had been broken. So camera lens should be changed.
12. Is it easy to open the camera and place the lens to its own place? No, any carefull person can repair it if there is no need to change any part.
13 You may read how to repair the lens from my another solution. The link is below:
http://www.fixya.com/support/t5026120-blurry_lens_but_not_dirty
I hope it is helpful.
Jun 15, 2010 | Samsung Digimax S600 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My Kodak M853 does not turn on and off as it did when new. the lens extends and retracts slow and the lens cover opens and closes slow, sometimes not closing at all. This happens under all battery...
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 21, 2010 | Kodak EasyShare One Digital Camera
Opens lens then switch's off, /fully charged
It could be the battery contacts or the battery itself that is faulty: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 21, 2010 | Kodak EasyShare V1073 Digital Camera
Lens was stack and wont open
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. I really hope this will work for you, but unfortunantly often when the product is dropped a mechanical problem appears. And there is nothing more than to order an OoW repair for this fault and model is 48 pounds. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak Easyshare 1725043 M893Is Digital...
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
When turning on camera the lens will open then shut off on a fully charged battery. It will allow you to view pictures on the camera by selecting the favorites and turning it on but when you turn the...
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Your batt. is covered under the same man. warranty as your camera.
Contact KODAK:
Nov 05, 2009 | Kodak EasyShare M863 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Camera won't turn on
look for a small pinhole (possibly under the camera) and insert a pin with batts inserted to reset the camera
May 24, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Weird problem. Camedia d-520 doesn't turn on. Blinks and Beeps.
I'm having the same problem with mine. Happens on rechargeables or brand new standard batteries as well. Very frustrating. I can't take more than 2 videos in a row without the dreaded orange/green lights flashing (low battery warning). Leaving it for 10-20 minutes and it works again, with the battery charge showing full.
Aug 14, 2006 | Olympus Camedia D-520 Zoom Digital Camera
HP Photosmart M517 Digital Camera Logo
111 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
