Question about Tannoy Reveal 6D Speaker
My Tannoy Reveal 6D Monitors are only outputting sound from the tweeters. I'm looking for troubleshooting suggestions.
  • relaxmusic Apr 19, 2009
    I have the same problem, what did you do?
    Im thinking of getting a new set of monitors rather than an expensive repair?
    Justin...
  • relaxmusic May 11, 2010
    Thanks lizzy, in the UK their repairs are handled by panic music, who are miles from me and it will be expensive to ship them over and then they will give me no idea of the min or max it would cost. All they have said is a qoute will cost me £65 + vat. Then we go from there.
    I have been advised they wont sound the same or be well balanced because of they are repaired they will have new and different components.
    I have a feeling I can get a new pair of monitors say KRK for a good price doing a new and modern job.?
    Thanks
    Justin...
  • 23 Answers
I still suggest calling Tannoy, They are usually very reasonable and will give you a fair price to service a very good product
Posted on Apr 19, 2009
I work in a church that has 4 passive speakers across the room, 3 out of 4 of them sound super muffled and n one of them sound perfect Ive tried switching power amps, there is no processing help?
I would say from your description that the tweeters are blown.
Can you take the speaker that sounds good and swap it out with one that sounds bad. If you do that and the good one still sounds good. You have a tweeter problem. And they would need to be replaced.
Apr 01, 2015 | Tannoy Audio Players & Recorders
Recently lost both tweeters in my Reveal 6-D's.Got replacements and highs are back after an easy install.While testing the speakers I noticed a '' plop '' when the woofer travels extensively with heavier...
Hmm, what killed the tweeters? Over-exuberant operation? What's going on with your amp? Is it being pushed into stress or distortion? THAT will kill a speaker faster than clean high power.
Mar 11, 2011 | Tannoy Reveal 6D Speaker
My Tannoy Reveal 5A Powered Monitors are producing a low hum. This is the case when in on or in standby mode, and is the case whether plugged in to an audio cable or not. Could you please assist with some...
Hi,low hum from monitor speakers are usually when there is not shield connected to the cables your using for connections. Also it might be from the power light,if there is no earth or ground connected before connecting the power source in that room.
So you will need to check the cabling properly and check how the (sleeve, tip and ring) are connected and also check the power outlet,if the (red,black and yellow or white) are connected properly.
after checking those if they are OK,that means the fault will be from the speaker itself.\
Just do a proper troubleshooting.
Thanks for using fixya.....
Oct 25, 2010 | Tannoy Reveal 5A Speaker
Tannoy reveal speakers have lost treble
What you need to do is connect a 1.5 volt battery to the speaker(s) terminals for a split second. Put your ear to the tweeter at the same time (you might someone to help you do this). If the tweeter "pops" it works, if not you might have blown them. The best way would (to be certain) is to remove the tweeter from the crossover inside the unit.
Tweeters are the first thing to go when the speaker has been connected to an amp that is wrong for them or they have been run at high volume.
Apr 20, 2010 | Tannoy Reveal 6D Speaker
My Tannoy Active monitors are connected to a Mackie 1202 VLZ mixer and have a distinct "hiss"... any idea how to remedy this situation?
Check the gain structure through the board.
Check all the mix bus assignmentsie what is routed to the masters.
Normally hiss can be reduced with good gain structure and ensuring all not being used is correctly turned off.
Test the speakers with another suitable source
If the speaker are less hissy on the alt source and you have checked all the mixer gains and eq, it is possible the board is noisy because of some component failure. Try audio isolation transformers on the output of the board, beg or borrow a good quality pair first to test, as they are expensive.
Thanks for using FixYa, I hope this if its useful
Oct 22, 2009 | Tannoy Reveal 5A Speaker
My Tannoy 6d monitor doesn't produce any sound
Hiya, i assume for now that you mean the 16dip switch. If i remember correctly it is solder directly to board (could be wrong). If you are comfortable with doing this, it will need to be opened and resoldered probably for dry joints. If not then suggest hunting out a friend with some solder experience. A word of caution though, shorting out solder tracks etc could result in damage so only do it if you are comfortable. If the dry joints are really bad (sound like they are) you should be able to see them clearly and resolder (look for not so bright and shiny solder that looks cracked. Magnifier helps)
Hope that helps
Jul 24, 2009 | Tannoy Reveal 6D Speaker
Tannoy Reveal 66D
One possibility is that the mute switches on your speakers have oxydized contacts INSIDE the switch - this kind of malfunction mostly occurs when the equipment is exposed to moisture and/or smog.
The most common solution is to change both switches, but they can also be disassembled and cleaned up (which is a bit more complicated and time consuming).
Another possibility is a dried up filter capacitor in the power supply or somewhere in the preamplifier section, possibly also a bad preamplifier chip but if your speakers work fine (with the exception of the mute switch noise), then the problem is more likely with the switches.
Also, check the internal connectors for any dirt, broken wires or desoldered pins.
Could also be something else, you should know i'm only assuming on the possibilities and i'm listing the most common problems i've encountered so far.
Regards
3rq8 (Triarcuate)
Jul 15, 2009 | Tannoy Reveal 6D Speaker
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
Tannoy Reveal 6D Speaker Logo
547 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
