Question about Konica Minolta DiALTA Di200 Copier
Dirty first copy of each batch run.
Product entry would not allow my Minolta Di 181.
On 11/22 you provided a solution to replace the pc drum. I can not find it listed as such in the parts catalogue. Does it have a different description?
Or might you have a part number?
Thanks
  • 145 Answers
YOU ARE RIGHT .
BUT YOU CAN ORDER IT BY GIVING THE MODLE NUMBER.
hope that help
Posted on Dec 12, 2008
Konica minolta 7255 error code sc 28-02
Below the drum is a assy. which has two/three very fine wires each carries a High Voltage (Only) during the copy process. the paper goes between these wires and the drum. The wires allow the paper to steal the image off the drum. Well these wire can become dirty, so they have a motor that runs a small cleaning pad across them, your code deals with that open the center section should see the assy. might be the one of the cleaning pads is stuck, the pads work go from one side (Rear to front/front to rear) to the other and back job done. Is the pad in the middle or stuck.
Remove the assy. and bring the pad to the front. Also can allow the motor not to do anything. In service mode 25.
Mar 17, 2015 | Konica Minolta Office Equipment & Supplies
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
No work machine code sc23-03
clean and inspect the drum cartridge replace the drum and the cleaning blade when was last time pm was done do be done ever 250,000 copies do one.
Mar 14, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
How to rest toner from black background
If the copy is dirty background first clean the optical parts component,mirror,lamp,charge corona,transfer unit.If it is OK verify the imaging unit developer and drum,if necessary change it.
Nov 30, 2013 | Konica Minolta Genuine Di181 Di-181 Ep1085...
Hw do i fix error code c0210 on my minolta dialta di 552
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
Mar 09, 2013 | Minolta Office Equipment & Supplies
Minolta bizhab di 3510 please wait problem
mam/sir Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Jul 10, 2012 | Minolta Office Equipment & Supplies
Reset drum minolta di 2510
Has the drum been replaced? IF not then recommend that the counter not be reset because the copier use the counters to determine voltages for certain assy. like drum and developer unit, so if you reset the counters with out replacing the parts the machine will give codes and provide bad copy quality issues. Reset code is the only way the machine knows it got new parts
May 29, 2012 | Minolta Di2510 All-In-One Laser Printer
My photocopier minolta di 183 is giving me error cof32 hw do l reset hv tried to run f8
Well need to replace the drum and developer running F8 with out changing the developer is not good, also make sure you clear the counter before replacing the drum and developer done toghter
Jul 25, 2011 | Minolta DiALTA Di183 Copier
MY MACHINE DI 181 SHOWS SERVICE CALL M4 AND DOES NOT COPY
This M4 code means that your drum life is over. You have run 80,000 copies or more on the drum. If you have a local service company available then I would just have them come out and clean the machine and reset the counter. This is especially true if your copies were still fine prior to the machine shutting down. Service mode entry and navigation is rather complicated on this machine so I do not feel comfortable trying to walk you thru the reset process.
Good Luck and Thank You for using Fixya.
Jun 10, 2010 | Minolta DiALTA Di181 Printer
Minolta di 181 error M4
This means that the drum has reached it life count of 80,000 copies. If your copies are good and the machine is still making copies the you can just ignore the M4 as if you are in the USA then the factory settting allows you to continue making copies. If the M4 appeared and you can NOT make copies then you will need to get into the service mode to turn the disable copy feature off or reset the count for the drum unit. Just let me know what your situation is and if need be we can walk you thru the reset. I just don't recommend this action unless it is absolutely necessary.
Apr 14, 2010 | Minolta DiALTA Di181 Printer
Konica Minolta DiALTA Di200 Copier Logo
70 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
