Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE 44xl gas stove (no electrical plug)
How do I light the pilot light on this stove? There is no electrical plug (I guess it's an oldie.
Is it just taking time to get the gas to flow through?
  • o2ka Dec 02, 2008
    fixed....I turned on the burner with the match at the pilot section and it drew the gas up to light. (just the other pilot would not light, but the burner did turn on--the gas is turned off until I fix that).
    If anyone knows how to clean it, please advise. Thank you.
I have a gas range GE 44XL it has an electronic ignition on the burners and a glow plug module fo the oven
Posted on Feb 09, 2009
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
Pilot lock light on stove is on so stove burners unable to work
This sounds like you may have to fix a problem in the pilot area before it will work. These gas operated devices have to meet a much higher safety standard than their electric counterparts. It is a built- in safety feature. Now, look for any obstruction or crimp in the gas line. My guess is you are not getting proper gas flow or pressure or the pilot could be physically blocked.
Feb 19, 2015 | Thermador Cooktops
Burners wont ignite
is this an electric start stove (is there a "light" choice on the knob)? If so, does it click? If it does have "light" and doesn't click, make sure it is plugged it and getting electricity. If not, then it is a "standing pilot" stove and the pilots are out. Let me know and/or good luck!
Aug 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Where do i find the pilot light on my ge profile gas stove
Are you sure it has one? A lot of the newer model gas ranges are "pilotless ignition." I had one that did and it had to be plugged into an electrical outlet and the outlet for some reason quit working, so the igniter wouldn't work either...
Jun 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
525 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
