Question about Whirlpool GD5SHAX Side by Side Refrigerator
Knocking noise coming from Whirlpool Gold refrigerator
Knocking occurs ocassionally
  • Anonymous Dec 10, 2008
    It is 4 years old and I hear knocking from the bottom a few times a day for about 30 seconds.
  • Anonymous Dec 18, 2008
    I have the same problem with a different Whirlpool : PBF1952PBW. Refrigerator is 30 days old bought from Loes it has a loud popping or knocking at 3 or 4 hour intervals. The repair man they sent me said I get to live with it because it cools properely. Paid $800.00++ for this dont buy Whirlpool.
    Jay,
    Tampa Florida
  • Whirlpool Master
  • 8,220 Answers
Mine does it too. I know what it is because I repair them for a living. That is the sound of ice expanding as the defrost heater comes on to melt the frost on the evaporator. The next ime you hear it make a note of the time. Every 8 to 10 hours it will go into defrost mode. The ice box will also quit working for 21 minutes.
Posted on Feb 20, 2009
  • Dan Webster
    Dan Webster Feb 20, 2009
    Another thing that will make the knocking is compresor mount too tight. They should be loose a tad to act as shock absorbers. Too tight and you get the knock when the box shuts down. Np worrys, just the nature of the ice box.
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: knocking noise coming from Whirlpool Gold refrigerator
The compressor is normally mounted in sound-dampening rubber shock mounts and it sounds as if one or more of these have decayed on your fridge.
Accessing the compressor from the back, you might try (gently) to rock the compressor to see if you can duplicate the noise you are hearing.
Posted on Dec 15, 2008
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
Knocking sound in upper left of refrigerator.
Yes, there is a ventilator (fan) for recirculating air. Looks like needs some maintenance (bearings regreased/oiled) or, if the worn is too high and blades are disbalanced, a new one.
Sep 11, 2017 | GE GSS25JEMCC Side by Side
Noise in water system on whirlpool refrigerator
You need to be more specific about the noise. If it's coming from the freezer area it could bethe fan motor. It is a common noise maker.
May 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Knocking Noise from the front, suspect the gearbox
If you know what you doing crack it open if not remove and get second hand box heaps cheaper.
It maybe somthing in the clutch either way you have to take out the box.
Feb 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Whirlpool side by side 2005...make to much noice
freon does not make a noise a compressor can if this noise is a knock then it is coming from the compressor and to solve it the compressor has to be changed
Apr 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5SHAX Side by Side Refrigerator Logo
1,623 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
