Question about B&W 5.5" TV/CD+G Monitor Karaoke Machine Television
Fleco Karokee Machine
I can play the first cd and when it changes to the next one it only clicks. I have tried new cd's but still wont work. It was pretty new and the store would not take it back as they said Fleco had gone out of business. Can you please tell me what to look for. Thanks
I need fleco karaoke cdg-11 manual
Try Googling (fleco)(cdg-11)(manual) without parens.
May 30, 2017 | Fleco Audio Players & Recorders
Fleco fm/am cassette music centre - has record player. All in excellent working order. How much is this worth?
They can be bought in a thrift store for around 20 dollars. With new technology and devices, there is no demand for them.
Feb 10, 2017 | Fleco Audio Players & Recorders
Please help, my ''Slimtype DVD A DS8A3S ATA Device '' won't work.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
May 01, 2012 | Computers & Internet
Airport tycoon 2 will not play in Windows 7
Its because airport tycoon 2 is not compatible with windows 7, it is only compatible with Windows 2000 and XP. But here try this one if it will help you. It will open a Windows XP inside your win7 .
  • First you will need to download this software. DOWNLOAD
  • After downloading the software, Run it and install it to your computer.
  • On the First Page of installation, just click Next
  • On the Second Page, Choose the destination folder where the software will be installed.
  • On the third Page, It will ask you, if you want to check updates during startup. Just Check the checkbox.
  • On the fourth Page, It will ask you to help improve the software, Uncheck this one because you wont need this.
  • On the Next page it will as you if you want to add shortcuts. just check all.
  • On the Next Page, Just click Continue to start the Installation process.
  • Wait for the Installation to finish.
  • After the installation is finished. The final Page will ask you to restart your PC, Choose Restart Now.
  • Now to create a XP on your WINDOW 7, you will need a Bootable Windows XP CD installer.
  • Insert the CD in your optical drive.
  • now open the software you installed.
  • Click on Create New Virtual Machine.
  • Now on the next page, Choose your installer disc. That will be your optical drive.click Next
  • On the next page, write your full name, username and password, click next.
  • On the next page, Write the name you want for the machine and choose the location where your machine will be saved.
  • On the next page, Write how much disc space you want. Remember that the size of the drive you will write will be deducted to the original size of your PC harddrive. And choose Store the Disk in single file.
  • Then click Next to start the machine.
  • This is also like installing a window XP on your PC.
  • Once the installation is complete, install your airport tycoon 2 there and try playing the game.
  • That's it.
Goodluck, Hope that my solution will help. Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a great day!
Jul 08, 2011 | Video Game Consoles & Games
I have a fleco karaoke machine the problem is that when you put a cd in the machine the word error appears what do i do please help
Hello. These karaoke machines can be a pain in the neck in that not all karaoke CD's work in every machine. Check in your manual to see which CD's are recommended. I had the same problem until I went to the home page for my karaoke machine and found the exact CD's that would play. Good luck with it. J.
May 22, 2010 | Sony STR-DB930 Receiver
After changeing few settings I can no longer play cd's/dvd's
If you have system restore set up, you can go back to before you changed your settings. If you are using Windows XP, click Start, All Programs, Accessories, System Tools, System Restore. Choose Restore my system to an earlier time, and click Next. Click on a day before the change, and time, click Next, and follow through the steps. If this does not work for you let me know, and I will try to assist you further.
Thanks
Mar 10, 2010 | Dell Inspiron 530s Desktop Computer
Need source for basic assembly info on FLACO CDG - 11.
Fleco is out of business. They offered NO support when they were in business.
The machine itself is a good one when it's working. If the upper unit is out your best bet is to replace it with another unit (using the existing box speakers and amp). If the Amp is the problem it can be repaired by a competent repairman That's willing to take his time. Schematic is not available. I repaired my own amplifier. The biggest problem is capacitors and little 8pin op amps. The parts are dirt cheap and available from several sources. (Mouser and Digi-key)
Feb 15, 2009 | Fleco Professional Karaoke System Shelf...
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
Televison & Video Logo
48 people viewed this question
Top B&W Televison & Video Experts
Are you a B&W Televison and Video Expert? Answer questions, earn points and help others
