Question about Microwave Ovens
My mother's GE microwave oven has a large burn mark on the ceiling of the unit. She noticed some plastic parts on the floor of the unit. She bought the combination microwave-stove about four years ago and noticed this mark about ten days ago and has stopped using the microwave..... Her problem is that the thing is attached to the oven and she is afraid that she'll have to replace the entire unit...any suggestions?
  • Microwave Ovens Master
  • 9,086 Answers
That would be the stirrer assembly. It consists of the stirrer motor, stirrer blade, and stirrer cover.
Without the stirrer in place, the oven will not cook evenly and may arc and spark.
Without the cover in place, food particles and grease can get on the waveguide and magnetron, and cause arcing damage.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you need to replace the stirrer motor, you'll probably have to pull the oven from the wall. You can download GE owner's manuals and installation instructions here.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Dec 08, 2008
Microwave oven not heating
This a good indicator the magnetron is gone, sometimes leaves odour that is destinctive.
Jun 19, 2012 | GE Profile PVM1790DRCC Microwave
Sparks from GE Microwave - HVM1540SN2SS
THERE SHOULD NOT BE ANY METALS IN A MICROWAVE WHEN THE UNIT IS RUNNING
If the unit paint is flaking and behind that flake is metal.. You need to throw it away or talk to your appliance guy and see if there is a speacial paint to coat the metal so you can use your MW
Jul 25, 2010 | GE Microwave Ovens
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
We have a ge microwave. Sparks came out of
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the mica waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
Sometimes it is the ceiling of the oven.
Your owner's manual may address this. You can download GE owner's manuals and installation instructions here.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.AC
Oct 10, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Non-Stop Noise from Inner Ceiling of the Microwaveoven
It sounds like the 'stirrer' which is a metal fan-like device with a plastic bearing that is mounted in the wave guide above the cavity. Pull the plug, then the case. Remove the waveguide above the cavity which should expose the stirrer. Spin it and check for any up and down motion--straighten the axle part so that it turns true. The blower system turns the stirrer--no extra motor. If this part was bent, someone may have handled it roughly. Reassemble the waveguide and test without the case on, but a cup of water in the cavity.
Aug 24, 2009 | GE Advantium SCA1000H Convection /...
Replace burned inside ceiling of microwave?
Do Not Use The Microwave. If You Need Parts Try Finding A Part Number And Use Ge To Order Parts. Click Here To Order Parts
Jan 15, 2009 | GE JEM31 Microwave Oven
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
In some models it is the plastic ceiling.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 13, 2008 | GE JES1384SF Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL Spacemaker microwave oven
I would first advise you to check the waveguide cover. This is probbaly a large one, covering the ceiling of the microwave.
If there is grease or food debris on it or above it, using the microwave can cause it to arc and smoke.
Otherwise, it may be a problem with the high voltage transformer or magnetron. It would have to be checked.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Oct 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
225 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
