Question about Cell Phones
Just vibrating ............no noise tried changing the setting and still the same
    Guru:
  • 558 Answers
Since when this problem started.  Have it got wet or fallen on ground?
May be its ringer get worn out. You need to take it to a repair shop for changing the ringer.
Posted on Dec 02, 2008
  • Puneet Jain
    Puneet Jain Dec 31, 2008
    Could you please let me know if the problem is not solved yet?
    And explain me a little why you putted a IA to me?? I wud appreciate if you put some HELPFUL or Thanks for trying rating to me.
  • 75 Answers
The speaker might be malfunction check tat
Will only vibrate when rec calls/txt. woke make any noise
Hi..
this might be because you have activated the vibration profile (silent), so go to the profile setting and change it to normal (general), moreover make sure that your speakers are working fine..
hope this will help you..
May 14, 2011 | Cell Phones
How to unmute or restore ringer sound on our spectralink e340 wireless phone
User options
Press FCN while on hook to change settings
(* shows current, follow display instructions to set):
Ring Type-select:
Normal (for an audible ring)
Vib/Norm (vibrates for five seconds, then rings)
Vibrate (vibrates until answered)
High Noise Mode-select:
Normal (for most office environments)
High (for moderate background noise)
Severe (for extremely noisy conditions)
Current IP address: may not be edited.
Extension number: may not be present for some protocols.
Additional options may be present
Mar 24, 2011 | Spectralink NetLink e340 Wireless...
Washing machine is working fine but has started making a real loud noise when spinning doesn't matter what speed or cycle it has always been real quite only had washer 3 years does not knock or seem out of...
As washing machines age some of the bearings and seals can begin to wear. After 3 years this wear my cause some noise but will not harm the operation of the appliance. Occasionally debris may become lodged around the drum. Visually check the drum for any lodged clothing, coins, plastic, etc. If you feel confident enough, remove the cover on the washing machine and check the drain for large debris.
If all else fails, installing an anti-vibration pad can lessen the amount of vibration/noise that you hear. Basically, even a small amount of vibration noise like you are describing can be amplified when it transfers to the floor of your laundry room. Try installing a set of small rubber anti-vibration pads like Silent Feet and you might be pleasantly surprised by the improvement.
If the noise gets worse or changes to a thumping or knocking, call you appliance technician or let me know. That may be the sign of something more serious, but I wouldn't be worried right now.
Feb 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Low level growling noise at rt. front wheel increases with speed. No change if in or out of gear. Can start hearing noise begining about 38 mph. very slight vibration Car has 77,000 miles and is well...
first rotate the tires see if there is a change. If that does not have a desirable effect there may be a worn wheel bearing,take note if the sound or vibration gets louder as you turn a corner, try left turns as well as right turns if the noise increases it is a wheel bearing.
Sep 22, 2009 | 2004 Toyota Camry
Ford Escape 2005 vibrating noise at road speed
try having the tires balanced first,if the problem persits then buy new ones.
Sep 08, 2009 | 2006 Ford Escape
High side low side pressures don not respond to freon levels
Chances are you have a TXV already installed. Thats why simply adding refridgerant is not effecting the pressures.
All you are doing by adding refridgerant is overcharging the unit, and possibly forcing the compressor to try to pump liquid instead of vapor. Not god for the compressor.
If the vibration noise is your only problem, I would try emilinating the vibration.
Find where the lineset is touching other parts of the house and install vibration dampening opads there. If the airahndler is mounted to the structure of the house, install vibration reduxction pads there too. If it is suspended from the floor joists you may have to change that mounitng method.
You can suspend the drain overflow pan and then set the unit in that on dampening pads, or set it on blocks from the floor/crawlspace.
Check your data sticker to find out how many pounds of refridgerant the unit takes.
By now, you are probably way overcharged.
Dec 11, 2008 | Ruud UAKA042 Air Conditioner
Turn vibrate on ?
let me sole it by steps do it step wise
press
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 | Cell Phones
Cell Phones Logo
115 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
