Question about Wacom ZC100 Mouse
Paper stuck under right click of wacom mouse
Need to know how to take apart the mouse to remove the paper
    President:
  • 8,637 Answers
Try using a thin pair of tweezers to remove the paper. Hope this helps. Bud
Posted on Jan 17, 2009
How can i install intuos gd 0608-u on pc running windows8.0?
The first thing you have to do is upgrade your Windows from version 8.0 to 8.1. Version 8.0 just has too many bugs plus it shouldn't automatically update anymore Check this MS page out.
Install the latest Windows 8 1 Update Windows Help
Here are the bare bones manual installation steps from the page:
Install the update manually
Make sure your PC is plugged in and connected to the Internet using a non-metered connection. Don't disconnect, unplug, or turn off your PC while the update is being installed.
Swipe in from the right edge of the screen, tap
Settings, and then tap Change PC settings.
(If you're using a mouse, point to the lower-right
corner of the screen, move the mouse pointer up,
click Settings, and then click Change PC
settings.)
Tap or click Update and recovery, and then tap or click
Windows Update.
Tap or click Check now.
If updates are found, tap or click View details.
In the list of updates, select the update containing
KB 2919355, and then tap or click Install.
If you're prompted for an administrator password or
confirmation, enter the password or provide
confirmation.
After the installation is complete, restart your PC and
sign in.
Note: If you don't see KB 2919355 in the list of available updates, you might be missing one or more required updates. Follow the previous steps to check for updates, install all important updates, particularly KB 2919442, restart your PC, and then check for KB 2919355 again.
Once you successfully update to Windows 8.1 we can tackle your Wacom products. There have been plenty of documented problems getting the Wacom Intuos Drivers working in Windows 8.x. Just google on "Wacom Intuos Driver Windows 8.1"
First get the latest Intuos driver version from the Wacom website.
http://cdn.wacom.com/u/drivers/ibmpc/pro/WacomTablet_6.3.11w3.exe
I couldn't find any separate drivers for the Wacom mouse
Oct 29, 2014 | Wacom Intuos Graphics Drawing Tablet...
How to put oppen the wacom kc 100 00 mouse
1.) Carefully remove both the felt backing on the bottom of the mouse and the thin clear plastic that it is stuck to as one piece. It is glued down with a thin adhesive and you will have to pry it loose with an x-acto knife or similar tool.
2.) Remove the 4 #0 Philips screws hidden under the felt. They may make a snapping sound when you pop them loose. don't worry, you didn't break anything.
3.) Turn the mouse upside-right and separate the two halves. The mechanical and electronic parts and scroll wheel are connected to the bottom half of the mouse, the left and right buttons. are connected to the top. there are some very delicate electronics in there, so be very careful.
This mouse is not meant to be taken apart, and doing so will void the warranty, but if you need to take it apart it is probably broken anyway. I was able to fix mine by simply cleaning the dirt out of it and am using it to write this post.
Aug 31, 2013 | Wacom ZC100 Mouse
Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Jan 20, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
The mouse on my Wacom Intuos tablet is not working.
I know this question was asked a long time ago, but I just had this similar problem and found a solution to it.
1. Install the latest Wacom drivers for your device
2. Open the Wacom Tablet Properties from the Start menu.
3. Click on the Mouse tool
4. Click on the Mapping tab halfway down the screen
5. Change the mode from Mouse to Pen
Dec 26, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Stuck mouse
Please unplug the mouse and replug it again. Let me know if the mouse is Ball Type. If it is Optical then, find out setting of Mouse in Control Panel and adjust them and test.
For Ball Type, remove the ball and clean all dust coming on it. also adjust the setting in control panel.
Oct 09, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Mouse right click broken.
I too have the same issue but it is intermittent. As a temporary work around, I set up the side button to act as a left click. I have yet to find a way to get the mouse apart to see what's up and at $65 to replace, I don't want to bust it completely.
Regards
Aug 19, 2008 | Wacom ZC100 Mouse
My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Jun 23, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Wacom Mouse XC-100-03 Right click doesn't work
Greetings,
You can buy any other style or brand of mouse and it will work right along side of the Wacom. I chose to keep my Logitech wireless mouse after installing my Wacom tablet because it provided a better feature set (i.e. more buttons ). I have had no issues. Please rate me well if this helped.
Take Care,
-WN
May 06, 2008 | Wacom ZC100 Mouse
Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Wacom ZC100 Mouse Logo
241 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
