Question about Rio Forge Sport Digital Media Player
My Rio says upgrader when I turn it on
I just put on some new songs and all was working fine.. when all of a sudden it won't turn on and it says upgrader on the screen. When I plug it into the computer I believe it says Rio in safe mode. Any suggestions on what I should do.. I am trying at the moment leaving the battery out for 20mins and seeing if that helps.. but so far nothing has worked.
  • 1 more comment
  • decktruck Mar 03, 2008
    IT WONT TURN ON AND SAYS UPGRADER ON THE SCREEN. PLUG IT INTO THE COMPUTER AND IT SAYS THAT THE PLAYER IS IN SAFE MODE. I HAVE TRIED THE TWO WAYS TO GET IT OFF AND THEY BOTH DONT WORK. WHAT SHOULD I DO??
  • Anonymous Apr 12, 2008
    i lost the software of the rio mp3 player. Don:t know where to download it...
    Thank you for your help ;)
  • Anonymous Aug 25, 2008
    Turned on my Rio Forge and all it says is Upgrader
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Posted on Feb 27, 2007
Warning Warning Warning - I take no responsibility if you melt your Rio with this solution, but it worked for me. I kept getting the UPGRADER message for my Rio Forge and would try all sorts of combinations to get it to work. Usually after about 15 minutes of fiddling with it, it would work. But then I also noticed that my Rio Forge would start after it had been in my pocket for a while. I remember reading some people's theory that the connections get weak. So, I took the memory card and battery out, and pointed the hair dryer at the insides for about 5 seconds. Now it works fine. I am so happy, I just love my little Rio player. I hope it never dies.
Posted on Jun 10, 2009
  • LUNA
    LUNA Dec 25, 2015
    yea thanks bro! it totally worked. i tried all that other advice for an hour or better and it did nothing. ran the hairdryer for about half a minute and badda bing there she was back online again. must be bad engineering or assemble/solder work flaws inherent in the product kinda like the 3 rings of death Xbox 360's get or how laptops just die out of the blue never to work again but because the Rio's are so small one is able to get them hot enough to affect the solder flow and enough to re-establish the integrity of the integral connections necessary for its operation.
I keep getting update
Posted on Nov 12, 2008
    Guru:
  • 155 Answers
If your Rio upgrader message (on Rio carbon 5GB, Pearl,2.5GB etc - hard drive players only) is not fixed by the other methods posted (resetting etc) then try replacing your hard drive, with a CF card, because you have probably broken it.
Everybody says that this does not work but it definitely does!
My Rio got dropped and I completely buggered the hard drive so after reading many forums saying that it didn't work I read one that said that someone had told them that sandisk ultra II ones worked (very vague!)
Because I had nothing to lose I went out and bought a 1GB sandisk Ultra II CF card. I then took apart my rio and replaced the hard drive with the CF card. Still not thinking it was going to work I plugged it into my computer and installed the latest firmware (from the rio website) and then HEY PRESTO!!!!!! it works.
I have yet to try an 8GB ultra II card but when I do i will keep you posted.
If you don't believe me then I don't blame you but If you send me a request then I can send you pictures and more details...
Rio will live on
Please give any comments, I would love to hear them
Mowcius
Posted on May 13, 2008
If Your RIO Cali says Upgrader and won't turn on Goto www.Electro.com/t25589400-RIO_CALI_FIX
Posted on Jan 22, 2008
One crazy RIO
funny mine is doing the same thing the day before i a leaving to go on a trip.
Jun 09, 2008 | Rio Forge Sport Digital Media Player
Having trouble getting my Rio Forge to work
Mine wasn't recognising the player through the USB cable so I followed Mantraguy's instructions to reload the firmware. Make sure though that you hold down the menu key before you switch on the player. Then it shows upgrade and you can reload the firmware. Of course you will lose all the songs on the internal memory but if it isn't working anyway.
good luck
May 23, 2008 | Rio Forge Sport Digital Media Player
Mp3 player wont download songs
I would recommend going into 'my computer ' and going into the music folder in your Rio. If your music is in here then make sure that it is a supported format (Eg. MP3, WMA. AAC is not supported)
If it is in here and it is a supported format then try formatting it and putting the tracks on again.
If that doesn't work then try upgrading to the latest firmware.
Hope this helps,
Mowcius
Dec 25, 2007 | Rio SE510 (512 MB) MP3 Player
2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Nov 19, 2007 | Rio Forge Sport Digital Media Player
Need help with rio forge mp3!! its messed up
Same problem here. No amount of updates or battery removal will help. Purging, re-downloading, reformatting...all failed. I'm afraid at this point there is nothing left to do but toss it.
Mar 29, 2007 | Rio Forge Sprot MP3 Player
Transfer error - Disagreement between player and software
I had the same issue and I eventually re-formatted the player. Once I had finished that, it seemed to work again, letting me add songs.
Feb 25, 2007 | Rio Nitrus MP3 Player
Rio forge 256 MB mp3 player
This happened to my player also. To fix it, you have to go to the rio website and download the most recent firmware for whatever model mp3 player you have. I went to: http://www.digitalnetworksna.com/support/rio/product.asp?model=265&SKU=90260558) Next install. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and follow the directions and it will see your player and upgrade the firmware (yes, even if it's the same firmware version.) You'll have to run the .exe file to get the upgrades onto your player. Unplug the player and it should be like new!
Oct 28, 2006 | Rio Forge Sport Digital Media Player
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Oct 12, 2006 | Rio Forge Sport Digital Media Player
No response AT ALL from player or on the computer
Go to http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235, Load the latest music manager. Then load the firmware upgrade.
Aug 19, 2006 | Rio CE2100 MP3 Player
The screen says "Upgrader"
Have you upgraded the software if not try that. Check your battery voltage if it reads around the 2. something voltage then you need to get that battery to its orginal capacity. I dont think you'll get your songs back. Does it have a reset button if so reset it.
Jun 10, 2006 | Rio CE2100 MP3 Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
4,226 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
