Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Starbucks barista expresso machine wont heat
HI, MY MACHINE IS ABOUT 2 AND A HALF YEARS OLD AND STOPPED HEATING. THE GREEN LIGHT WILL NOT COME ON INDICATING ITS WARMED UP, NOR WILL IT MAKE STEAM. THE PUMP WORKS FINE. DURING THE LAST COUPLE OF USES IT MADE SOME POPPING NOISES WHILE HEATING (LIKE PRESSURE NOISES). IM THINKING THE HEATING ELEMENT IS A GONER. ANY ONE KNOW WHERE I CAN GET ONE OR HAVE ANY OTHER IDEAS?
P.S. MY MACHINE IS OLDER, NOT DIGITAL AND IS A SAECO.
THANKS
  • 29 Answers
Http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
check out this site at the bottom u can find the manual
Posted on Feb 27, 2009
    Genius:
  • 1,199 Answers
GO WITH YPUR FIRST HUNCH! THE ELEMENT
Posted on Dec 07, 2008
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Mar 06, 2010 | Saeco Starbucks Sirena Espresso Machine
My Starbucks Grand Barrista 12 cup coffee maker stopped working.
from what i can see they have pumpo issues..... try your warranty although i guess that'd be long gone after your many "years" of ownership.... anyway, get an expresso machine, they produce much better coffee by far :) Goodluck, CHA55Y....
Jun 12, 2009 | Starbucks Barista Quattro Coffee Maker
After descaling the two coffe cup lights keep flashing .
Hi
You have finished the descale process and your descale light should be gone. Put a fresh tank of water on the machine and then open the steam knob. This should clear the water light and your machine will start heating again.
May 24, 2009 | Starbucks Saeco Italia Digital Barista...
My Starbucks Barista has stopped working
It could be vapor locked like mine was. I have a starbucks barista espresso machine and had the same problem. I called starbucks and they walked me through manually priming the machine from the back to break through the vapor lock.After 2 tries it finally worked and i can use it again. Its a time consuming procedure but worth it.Call them at1-800-334-5553 They are great.
Mar 22, 2009 | Starbucks Saeco Italia Digital Barista...
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Starbucks Barista Espresso Machine Ready Light Went Out
Call Home Espresso Repair in Seattle. I've used these guys a couple of times, and they're wonderful. Once I wasn't getting any steam, and the guy told me how to open up the case and make a simple adjustment of a set screw that probably saved me big bucks.
I was actually just there today to pick up some O-rings for the steam valve. Charged me $1. And that includes replacing them for me (I had removed the stem and brought it in).
My Rio Vapore (earlier version of yours) is now 17 years old, and I give H.E.R. a lot of the credit for that.
Oh, and did I mention that back in the days when Starbucks was small (many moons ago), they were the in-house service center for all the machines Starbucks sold?
Their number is (206) 789-9513.
Good luck.
-Kevin
Oct 18, 2008 | Starbucks Coffee Makers & Espresso...
Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
/Mirran
Sep 05, 2008 | Starbucks Saeco Italia Digital Barista...
Barista Coffee Expresso machine
yea, that happens to me. Try this way....Turn on the Barista, wait til the the steam's green light, then push the steamer button on, wait for a good 1 minute. It should be blowing hot air by then. Good Luck
Aug 22, 2007 | Starbucks Barista Utopia
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
301 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
