I have an optima 50 dlp tv the bulb was suspected as going out, so I replaced it and it worked for about 20 minutes. I shut the tv off and now it says the bulb needs replacing again. WTF little help.
This is what happened to me and frequently happens. I beleive this happens when the tv becomes too hot. What I did is diconnected the plug from the wall and it helped. I think that it needs to reset it self to be able to detect the new bulb. See if this works...
Posted on Apr 19, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Wd60636
Never really had that issue the one I worked on Operated normally for 20 minutes and then shut down completely. The fix for that is to get the OEM bulb instead of the replacement
Jul 08, 2014 | Mitsubishi WD-60638 DLP TV
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Tv comes on for a minute and then I get the bulb failure light. If I unplug it and power it back on I get the same result, so it is not the bulb because it still works. What is causing this?
The would be the balast that holds the bulb that has give way, this would need to be replaced as its setting of a signal to shut your tv down.
I hope this helps
Aug 04, 2009 | Philips 50PL9126D/37B 50" DLP TV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
