Question about Edimax BR-6114Wg Router (BR6114WG)
Issues with the BR-6114WG
This happens pretty regularly (as in several times a day): The router becomes unresponsive. Lights on it still blink and it *appears* to be working and still shows up on the list of available wireless stations but no connected PCs can access the internet, each other, or the router (via its IP address). The signal strength shows as great or excellent so it's not a problem of a weak signal. Also, when it does "this" I can't successfully repair connections on my wired/wireless PCs. Unplugging the router and plugging it back in fix the problem temporarily. I've tried resetting, upgrading the firmware, downgrading the firmware, etc to no avail. I have a friend with this same router and the same problems came up after a year or so of having it.
    President:
  • 2,961 Answers
Depending on how your router is set up, it may be a DNS problem. Start from beggining and make sure your router is enabled for wireless, wep or other encryption is off, DHCP is enabled for assigning IP addresses automatically. Run this programme on pc's, click Start>run then type ipconfig /flushdns then press enter. Clean out your old cached and temp files. Go to your wireless adapters properties and ensure that they are set to obtain ip address automatically in TCP/IP settings. Restart systems and hopefully you are away. Every time you use windows to repair the connection it will try to re-new IP addreses, but it won't be the one your router uses, so don't use it, as you will lose connection to the router.
Posted on Jan 31, 2007
GT-19100T mobile phone and i have put sd card in phone but it doesnt tegister there is one...it is the right sd card...how do i fix?
Samsung Galaxy GT i9100T: MicroSD: how to mount:
Settings>Storage>(scroll down)..
and you are saying it does not register as being available.. this means that the card is unformatted or it could also mean that it got corrupted (possibly when the phone was still writing to the card but you took it out of the phone before it could finish) or damaged or the write protect lock on the card is locked.
If you have a Windows computer you can try fixing the SD card using CHKDSK (the /F means Fix).. see this link for instructions:
Fix Any USB SD MINI MICRO NO FORMAT NEEDED
SD SDHC Card Problems and Fixes Card Locked Card Error No Memory Card...
Jan 14, 2016 | Samsung Cell Phones
Edimax-11g-router
Ok. So what is the problem you are having?
Nov 10, 2013 | Edimax BR-6114Wg Router (BR6114WG)
My NAT type is set to strict, how do i change this?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 30, 2010 | Edimax BR-6114Wg Router (BR6114WG)
Samsung fpt5884 plasma TV power issues
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Televison & Video
My laptop can't connect with my wlan edimax router BR-6204Wg,,,, wlan light indicator flinks orange,,,
Reset everything including the Hard reset (a small probably hidden button you must press for 15 seconds) you will find somewhere on the wireless router. I trust your laptop is capable of connecting wirelessly???and you have done this before???
Sep 21, 2009 | Edimax BR-6114Wg Router (BR6114WG)
Bad signal at home
Free and easiest way to fix a signal problem in a house:
http://www.freeantennas.com/
Should boost your signal by a couple decibels
Apr 30, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Always disconnect
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Apr 17, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Edimax wirless router 6114Wg needs restart to start working
Sounds like a port issue. Follow the below link for more info on port forwarding. This needs to be done for programs like utorrent or emule and many others. http://www.portforward.com/english/applications/port_forwarding/Utor/Utorindex.htm or just check out http://www.portforward.com Good Luck
Sep 27, 2007 | Edimax BR-6114Wg Router (BR6114WG)
Random Disconnection and WLan indicator lights
Saw this on another post for this router: "in the DHCP configuration on LAN menu. the lease time was set to 72 hours (3 days) i change it to 720 hours, cos that was the most it would allow... so hopefully that would fix it. " maybe you're having the same problem. another usefull thing to do is to update the firmware from the D-link site. some stability issues such as this should be fixed by a firmware update. post what happened goo luck ;]
May 10, 2006 | D-Link DSL 604+ (DSL-604+) Wireless Router
Edimax BR-6114Wg Router (BR6114WG) Logo
171 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
