Question about Acer InviLink 802.11b (91.49C10.002) Wireless Adapter
Ac adaptor question
On the wire going TO the plug, one side is black, and the other side is black with 1/2" white stripes.
Please tell me what side is the positive?
Thanks!
  • Jane Doe Jan 04, 2009
    Because the end of the adapter should be positive and outside negative.
  • 4 Answers
I am afraid to ask why, but it really doesn't matter. It uses alternating current, so both wires are positive and negative throughout the cycle.
OK, I'll ask. What are you doing that would make you concerned about which is which?
Posted on Jan 02, 2009
  • jtb74129 Jan 05, 2009
    in most applications the wire with the stripe is designated positive.
2 WIRES PULLED OUT OF THE PLUG ON BACK OF ALTERNATOR ONE WHITE WTH RED STRIPE ONE BLACK WTH WHITE STRIPE WHICH ONE IS IN THE CENTER
dont guess.
ouch, the FSM shows all connector pin outs in the rear.
you never said the year.
nor country diff, countries have different harness colors.??????
my 04' FSM shows.
2 wires. (not counting case and big wire)
the 2 plug. called A11 plug.
a11 pin 2 white red. charge lamp.
a11 pin1 black white,,, IG fuse.
but where are the, page 9a-16 shows that.
harness side,
key up, locking key up
1, 2 , X ( x is blank socket pin) left to right.
1 blk-wh
2 whit red,
or go to alldata dot com and look.
Sep 22, 2013 | Suzuki XL7 Cars & Trucks
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Oct 11, 2010 | Metra 705512 Ford Prm Snd Amp Plug Wiring...
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Plug wiring
When wiring a new plug for which voltage input?
The cutter has a white wire, a black wire, and a green one - white is the neutral line, black is the hot line, green is ground.
You can see this in section 4-9 of the owners manual, if you don't have a manual you can go to www.millerwelds.com and get a PDF file of the manual.
Rank this answer please,
Carl
Nov 26, 2008 | Miller Welding Tools
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
Computers & Internet Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
