How do I clear my sharp ar 287 showing code F2-00 ?
My sharp ar 287 is showing code F2-00 after toner refill
  • 1 more comment
  • sam827 Dec 04, 2008
    I am not at the machines location at this time but the toner cartridge is not the removable type. You just fill the resevoir from a toner bottle. In any case I will try to pull the plug, maybe that will work.
  • sam827 Dec 09, 2008
    I unplugged the Sharp AR 287 copier for 30 minutes and the same code appeared F2-00. Any other suggestions?
  • sam827 Dec 16, 2008
    Does anyone know the "key Operator Code" for the Sharp AR 287 copier? maybe I will be able to clear the F2-00 error code from there.
  • 275 Answers
It is a toner error
Posted on Dec 16, 2008
    Sergeant:
    Novelist:
  • 327 Answers
U will have to call the service center sharp to reset the printer error codes.as they r not listed on the sites openly to do it manually.
    Sergeant:
  • 399 Answers
Its the problem of the toner sensor in the machine.as the cartridge is not getting detected in the machine so this error,because the sensor is moved it needs to be made proper or if the sensor in bent/broken it needs replacement.
Posted on Dec 09, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Most Sharp have the error F2-00 as Toner Sensor Problem. This is different from the "TONER SUPPLY IS LOW. PRESS 1 FOR GUIDANCE" which indicates that the machine requires additional toner. Error code F2-00 is an indication that a hardware fault exists, the sensor itself, not the toner, is needing attention. In some instances, this would only require cleaning the sensor and the toner reservoir.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    and in some instances, not only cleaning and not recommended to simply reset. As earlier posted, a hardware fault exists. On along the same series (but different model) AR-336, the recommended procedure:
    "empty out the toner hopper (are you wearing your black shirt?). Examine
    the foam roller. If you can see light down through the slot where the
    toner feeds replace the foam roller, end seals, and developer. Refill
    toner hopper. Run sim 14 to clear code, sim 25-02 to set developer, and
    sim 24-5 to reset developer count.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 928 Answers
It would be best to unplug the machine for some time then plug it back in. that normally resets the internal memory of the unit.
  • 6,487 Answers
Try first to power off the printer for about 30 minutes and unplug it from the computer and the power outlet then check if its already working....
  • Mark Gil
    Mark Gil Dec 11, 2008
    If you're still receiving the error the machine is detecting the toner that is connected to it, there's a possibility that the toner is bad or something...
    Sergeant:
  • 217 Answers
Remove the toner and unplug the machine for two minutes.then again on the device and reinsert the toner.the toner is not getting detected by the machine.
  • llincon Dec 04, 2008
    http://www.visualhawk.vcc.ro/sharp_error...
    click this link and see  F2-00 error.it is given.
    and also this another link
    http://www.unitedtechsonline.citymax.com...
    this link says
    F2:
         00:TONER SENSOR
         02:TONER SUPPLY PROBLEM
            04:WRONG COUNTRY,WRONG CARTRIDGE,CRUM
         05:CRUM PROBLEM,WRONG CARTRIDGE
         39:PROCESS UNIT THERMISTOR PROBLEMS
         58:PROCESS HUMIDITY SENSOR PROBLEM
    To fix: empty out the toner hopper. Examine the foam roller. If you can see light down through the slot where the toner feeds replace the foam roller, end seals, and developer. Refill toner hopper. Run sim 14 to clear code, sim 25-02 to set developer, and sim 24-5 to reset developer count.
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
What code do i use to clear toner alarm indicator
it can't be cleared until you change the toner sensor
Jun 07, 2014 | Sharp AR-5516s
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
I have a sharp ar-235 what does call service code U2-40 mean
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
387 people viewed this question
k24674
