Question about Zenith B25A74R 25" TV
FUSE BLOWS EVERYTIME I PLUG THE TV IN
OLD ZENITH # SEC3133H.
  • kat48071 Dec 02, 2008
    THANK YOU
    Sergeant:
    Champion:
  • 346 Answers
Change the horizontal output transistor
replace fuse with exact #
repairs must be done by a qualified tv repairman
Posted on Dec 02, 2008
Everytime I plug my 2yr old phillips 50 inch lcd into the socket[s] I blows the fuse ,any ideas
Short circuited component/s inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 02, 2014 | Televison & Video
When I plug tv in it blows the fuse
Replace the power supply board..
Feb 23, 2012 | Zenith Televison & Video
EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT BLOWS THE 12 AMP 125 V FUSE INSIDE. REPLACED THE FUSE MULTIPLE TIMES WITH THE EXACT FUSE RECOMMENDED AND IT STILL BLOWS. THE UNIT IS ONLY 1-2 YEARS OLD. ...
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Jun 30, 2011 | Amana D545M Dehumidifier
Plug in no power
Check the fuse inside the TV. If fuse blows, there is a problem elsewhere.
The initial spark you are mentioning is due to degaussing coil. This is not routed through fuse.
Apr 07, 2010 | Zenith A36B41W 36" TV
Tv blowing fuses
More likely to be either shorted out bridge rectifier or MOSFET in the primary circuits of the power supply. You need to Ohm out those parts.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sylvania+LC320SS8+
Dec 22, 2009 | Sylvania LC320SS8 32 in. LCD Television
The power safety fuse was blown. I replaced it but everytime I plug the TV, it blows the fuse. It is a Sony projection HDTV
When fuse blows again and again that means power supply is bad and needs to be replaced.
Let me know exact model of your Sony TV to provide you power supply board part number info.
Nov 03, 2009 | Sony KP-51WS510 51" Rear Projection...
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
FUSE BLOWS EVERTIME I TURN MY TV ON. I CAN REPLACE THE FUSE AND DISCONNECT THE FLYBACK FROM THE CRT,TURN THE SET BACK ON ,CHECK THE FUSE IT WOULD STILL BE GOOD,BUT WHEN I REINSERT THE FLYBACK AND TURN THE...
Possibly a resistor that's becoming defective... it's changing value thus increasing current. like if the resistor has a rating of a 10k Ohm and now it's changing to a 30K Ohm and the current (amps) is supposed to be around .50Amps and now it's rising to .75Amps or higher, so it would blow the fuse so as not to further damage any other high voltage or sensetive component. Is the fuse you are replacing the same as rated for the tv? ie; 250V 1.25Amp FB (fast blow) or SB (slow blow) it should say on the circut board where the fuse plugs into.
Jul 17, 2007 | Zenith C27A24T 27" TV
Zenith B25A74R 25" TV Logo
85 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
