Question about Philips TS3661C 36" TV
Piture expands and shrinks while viewing tv
While i'm watching tv the piture starts to expand and shrink ,it looks like someones chest while there breathing. in and out.The screen will be normal at first then expand, then go into a breathing mode,
  • nate wade Jan 31, 2007
    the tv is a philips ts3361c-36"
  • 556 Answers
SOURCE: fading fast
it looks me that thare is a loose contact in your power sypply section of your tv. both the problems will be okay if it is rectified by a skilled tech.
Posted on Sep 27, 2007
rey jr
  • 149 Answers
SOURCE: Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Posted on Feb 18, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Television screen keeps shrinking
Easy fix. Check www.magnavoxhelp.com for a repair kit.
Posted on Jun 29, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Posted on Oct 14, 2008
Ecollier2012
  • 3459 Answers
SOURCE: picture shrinks and expands
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. You can find a repair kit here http://www.TvRepairKits.com . Hope this helps.
Posted on Nov 02, 2008
No picture, last night color was going away, then today no picture
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
0667c5f.pngSOLUTION
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Nov 17, 2009 | Philips 9P6031C 60" Rear Projection...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips TV problem
If the video shrinks and expands you can get a repair kit from www.TvRepairKit.com.
Mar 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips TS3661C 36" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
