Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 SPARKS IN REAR
My RCA is 2 1/2 years old, not under warranty anymore. Yesterday I heard loud noise, I jumped up and looked behind. There were sparks coming out of the back. I unplugged it. It is going to cost $100.00 just to get it looked at. Is it worth fixing? or Should I just replace it?
  • Kristi Pryor Jan 31, 2007
    Thanks! Yes there was power when the tv sparked...and it did not trip the breaker...A friend said it most likely was the transformer?? Have you ever heard of this before?? Thanks again!!
    President:
  • 1,284 Answers
The high voltage transformer could be the cause and isn't that tough to replace on RCA's. The units I have seen "spark" have had holes in the side of the transformer which allows 30KV to find its path to ground anyway it can. I wouldn't suggest just the average person attempt this repair though.
Posted on Feb 01, 2007
    Problem Solver:
  • 12 Answers
Was there actually power when the Television was sparking? I would suggest replacing the power module and having someone test the voltage coming out of the plug it was plugged into did it trip the breaker?
Posted on Jan 31, 2007
SOURCE:
I have a 52in rca tv that will not power up anymore. when it is plugged in, i am hearing a "Ticking" noise. What is this?
The ticking noise is almost always caused by the flyback and or HOT transistor which an be obtained from www.tvrepairworld.com and the flyback and Hot come with installation instructions.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
My rca d52w19 projection television started to make a crackeling sound like water dripping on a hot skillet. now it is making a loud pop and when it does the screen goes out and back on again. i have been...
The loud pop you hear is a spark gap being jumped. That might happen once an awhile naturally due to a voltage spike but if it's happening regularly chances are something needs replacing. Capacitors are prime suspects for aging, in fact when a capacitor(big one) blows it sounds just like that.
Aug 10, 2010 | RCA D52W19 52" Rear Projection Television
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
Yesterday, I went to use the microwave and as I pushed start, I heard a loud pop and saw sparks behind the vent cover. The microwave light and turn table work fine, but it does not heat. Is it repairable?
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Oct 07, 2009 | Whirlpool Microwave Ovens
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA Rear projection Tv D52W25
the would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Jan 09, 2008 | RCA P52926 52" Rear Projection Television
52 in rca D52W19 turns on and then turns off. This has happened before.
Do you still need help with your televisions? RCA is having alot of troubles with these tvs.If you are still in need of help reply back. Thank You for using FixYa and Have a Nice Day.
Dec 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
93 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
