My Samsung Color laser printer indicates all four color toners as 'invalid' despite changing them. It also indicates the imaging unit is invalid. It was bought new and functioned without any problems for six months and then stopped printing or copying etc. The model no is CLX-3160FN
  • 3 Answers
When you changed the toner did you change the chip for them? you need a special chip for each and evry one of them. I had that problem with my CLX-2160 and i fixed it this way.
Posted on Dec 19, 2009
What solution for samsung clx3175 asking intall image unit
Dear ,
Kindly refer the following link,
http://www.samsung.com/us/computer/printers-accessories/CLT-R409/SEE
This imaging unit needs to be replaced after it complete its life (6000 color pages/ 24000 mono images)
To replace first you need to takeout the toners and waste toner container ( a transparent/black container on the left hand side)
after that you may take out the imaging unit.
after that put the new imaging unit.
put the waste toner container and put back the toners.
If problem persists please provide your feedback.
Best Regards
Apr 19, 2012 | Samsung CLX-3175FW Multifunction Laser...
I have Samsung CLX 3175 laser printer. Am getting invalid toner message although parts are genuine
Well, eventually I worked it out: The "contacts" are four square fields to the left on on the backside of the cartridge. And it works instantly. (I read somewhere that it needs to be fully transparent tape. The 'blurry' tape leads electricity and doesn't work.)
Mar 13, 2012 | Samsung CLX-3175FW Multifunction Laser...
I replaced the image unit and the message that the image unit needs to be replaced does not go away please help.
Hi
Have a look at page 69 of the user manual.
http://static.highspeedbackbone.net/pdf/Samsung-CLX-3175FW-Color-Laser-Printer-Manual.pdf
Make sure any senors are clean.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Ghost image towards bottom of page. Does this indicate my drum should be changed out?
Hey
if its a standard black toner printer your drum will need changing its probably not the photo drum itself but the cleaning wire that is attached to the drum unit is dirty...but there is no way to fix this but to replace the drum module..
If its a color toner it's the same thing the "drum" needs to be changed but in a color toner printer it's actually called a transfer film.
hope this helps,ben
Jan 04, 2011 | Dell 3010cn Laser Printer
It tells me to replace the imaging unit i did but it still is telling me to replace the imaging unit any tips on how to resolve this?
sorry about my last reply. you have to replace the selenium DRUM, its a big drum inside the printer under the toner. It cost 150USD... kinda hate Samsung right?
you can also just take it out, shake it left to right several times and put it back and see if you still get the error.
"Pull down the front cover and you have access to the four toner cartridges, which are lined up, one above the other, inside. Unlike many recent colour laser designs, the drum unit is separate from each of these cartridges and has a different lifespan, as does the toner waste bottle, which also needs replacing periodically. "
Samsung has a chip that counts the number of prints you do. After X prints, it wil make you change the toner even if you do not need to. Also you have to replace the selenium drum and also the waste toner bin... I HATE SAMSUMG from now on... CHEATERS
Aug 23, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
CLP-315 - CLP-315 Laser Printer: I have changed all the color toner but not prining...
any error indicated?
run your Smart Panel and check what is the fault that is being detected.
If all the color toner had been replace. what about the OPC & waste toner tank?
note. Please replace the waste toner tank once it is full do not reuse the same waste toner tank. as it will course the internal of the printer to be spread with waste toner and your print out will be dirty and patches.
May 16, 2010 | Samsung CLP 315 Laser Printer
I bought a used Color Laser printer, the HP1600, and I have just installed three brand new color cartridges. When I attempted to print the color came out washed and very faded and you could see it being...
This could a problem with the laser scanner assembly. It gets contaminated with toner and dust so reduceing the laser intensity which in turn causes the image to be fainter and gives it a washed out appearance. You would need to remove the scanner and clean the lenses and mirrors for each toner cartridge. The laser scanner box is one unit with four mirrors and four lenses in it.
Oct 07, 2009 | HP Color LaserJet 2600n Printer
Samsung clp-510 .The image had bad color
please shake well to your toners.then verify your toner. if any scratch is appear then please change the toner.
Mar 20, 2009 | Samsung CLP-510 Laser Printer
Printing color problem
you need to place a service call, it sounds like the imaging unit is need or replacement
Jan 07, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
640 people viewed this question
jasbo
jasbo
