Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher & Paykel DD603 setting the water pressure
The lower drawer is acting erratic. It restarts about 1-2 minutes into the cycle and keeps doing this. In selecting a wash cycle every once in a while it shows a red LED with "LP" but I can not find in the user manual or the service manual what steps to do to set the water pressure to HP.
Neither drawer will go into the options settings using the button sequences in the manuals either? The top drawer runs with no problems.
I cleaned the lower filter and plate. I ran a small tube brush into the drain pipe up to about the blue impeller. It will pump water out through the sink. It also will pump some of the water into the upper drawer if you have it shut, otherwise the water all goes through the sink.
  • 145 Answers
First off, clean the surface where you select the cycles, over on the right side of the drawer edge. Clean up the entire surface, so that when you lightly touch the cycles, It changes instantly. Also, you said "dd603" but the LP/HP modes are for model 601 and 602.
Open the drawer, select normal first. Now with two hands, hold your fingers over the two outer-most buttons, one on the left side and one on the right. Wait up to six seconds and then the LEDs should all come on in an orange color and the display should show the LP. Press the lock button once, it should change to LP. Make sure you are looking for a manual for a dd601/602. You can get them free at http://www.fisherpaykelparts.net
Posted on Dec 11, 2008
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
MY FISHER AND PAYKEL DD603-SS BOTTOM DRAWER IS NOT DRAINING. HOW DO I FIX THIS?
Do you get any error code on the display?
Does the cycle complete or dishwasher keeps running?
Do you hear the pump trying to drain?
Is it happening in all wash cycles or some?
The easiest thing to do is to check if the filter at the base is clean.
I am assuming the kitchen drain is clear because the other drawer seems to work normally.
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
370 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
