Question about Samsung SGH- B300- DARK GREEN Cellular Phone
I need a new body
I got a new samsung bh300 i live in india and i lost the back side battery flap of my bh300 where can i get the new back side battery flap in india jaipur is it available in jaipur???
  • 107 Answers
Hop on ebay
4onesexpress-07802458019
Posted on Dec 02, 2008
If you put a ladder in the back and drive down a bad road that what my front end sounds like 2005 dodge ram tried new shocks new ball joints checked it all ?
so what else is loose
check stabilizer bushes , bumper bar bolts , grill fittings , external lights , engine mounts , loose splash pan under front, mud flaps , inner guards loose , battery fitting, bonnet latch tight , body insulators on chassis frame , rusted body panels
Aug 21, 2016 | Dodge Cars & Trucks
Lost samsung corby touch phone can i deactivate it so that no body else can use it
SORRY FOR YOU. Once I lost my phone, I blocked and deleted all my private files to protect my privacy. Try it!
May 29, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How can i change the body of samsung u900
GO TO EBAY THEY SELL BACK COVERS ETC WITH BATTERY ON IT
May 06, 2010 | Samsung SGH-U900 Flipshot Cellular Phone
Battery Backup of my WEP 200 Bluetooth Headset
I purchased new Samsung WEP 200 Bluetooth Headset but its Battery Backup is not even 1 minute. From where I can get the battery. I am based in Vijayawada, (A.P) (India) & what could be the approximate cost.
Oct 29, 2009 | Samsung Bluetooth?® WEP200 Headset...
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
I have using Nokia 1100 ,while speaking More than 20 mins, mobile has heated .my battery is :BL-5C how to solve this problems , plz help me by--Siva
in all mobiles when u get this type of problem. power amplifer heats when we talk more. change the pa (power amplifier) through nokia service centre or any professional.
amit singh (service eng.)
samsung india electronics
kanpur
india
amit9902@live.in
Feb 28, 2009 | Nokia 1100
Choke sticks in winter
clean the throttle body and flap. with the a tooth brush and throttle body cleaner from the parts store.this should fix the sticking im not sure about your stalling problem. also after you clean the throttle body and flap. it will be hard to start at first until all the cleaner burns out of the engine. its normal and will clear up in a minute or so. make sure you clean both sides of the flap. by holding the throttle open while brushing and spraying into throttle body. good luck.
Nov 22, 2008 | 1996 Dodge Ram
Iac and throttle body
Cleaning the throttle body is no big problem; simply remove the air filter box, and remove the tube from the air filter box that connects to the throttle body. Spray carb cleaner on the flap valve and all around the flap valve. Regarding you idle condition, cleaning the Idle Air Control valve (IAC) may do you no good. Once it fails, it is usually done. You prob need to install a replacement IAC. It is UNDER the throttle chamber, you will see it when you remove the air tube to the throttle body. I change several of these a month. Common failure.
Sep 24, 2008 | 2000 Toyota Camry
Samsung SGH- B300- DARK GREEN Cellular Phone Logo
60 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
