Question about Bugaboo Cameleon Jogger
Brake does not engage
The brake on my Bugaboo Chameleon stroller does not engage. I've contacted the company and they may send a new brake but I have no idea how to replace. Any suggestions?
The brake disengages using the button. if it is forced the mechanism slips. its fairly straightforward to take it apart with a screwdriver. clean the plastic parts, put it back together right and screw it back on. then all you need to do is show granny how to work it (again) to prevent it happening again.
Posted on Sep 15, 2008
Try pushing the brake handle a bit further to get it to engage fully, ours only locks the brakes in the furthest handle position.
Posted on Mar 06, 2008
My brake broke after just 3 weeks of use. Called Bugaboo, and they're sending me a new frame (supposedly they don't ship out parts, just complete assemblies). They said all I have to do is swap my wheels and fabrics over, and ship them back the old frame. Sounds easy enough. On a side note, I had originally brought the stroller back to my place of purchase, anf their display stroller had a busted brake as well.
Posted on Sep 19, 2007
  • 3 Answers
You can ask the company how to replace the brake. It shouldnt be too hard. If you know someone who is handy they will be able to help you with the instructions they give you.
Posted on May 16, 2007
I need a brake level for a bugaboo camelon tried to repair internal parts and spring and it is all jammed up and not salvagable. I simply need a resource for a new lever
If the lever is not broken and the teeth still have their points and engage well with the matching teeth on the fixed lever bracket it should be repairable. It is fiddly to get all the parts lined up and assembled most likely you've got the brake cable wedged. If you do need a brake lever Bugaboo won't help they only sell the whole chassis. If you have the older wing-nut white lever model you will get back some of the $400 new chassis cost in better resale value. Other wise check out eBay for old chassis with other problems but good brake parts. Here's my link about Bugaboo brakes www.fixya.com/support/r7805449-fix_bugaboo_brake
Sep 07, 2011 | Bugaboo Cameleon Stroller
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
Cameleon Jogger Stroller: The brake cable has snapped on my Bugaboo Cameleon...
You should contact www.buggypitstop.co.uk they are the only company I know that sells bugaboo spare parts like brake cables and levers.
May 18, 2010 | Bugaboo Cameleon Jogger
Brake on my chameleon keeps releasing too easily. When the brake is applied and you push the pram it releases too easily, so basically doesnt work. any ideas?
This sounds like the cogs within the braking system are broken, If you visit www.bugaboo.com you will be able to make contact and purchase a new brake repair kit that should solve the issue.
Hope this helps.
Feb 08, 2010 | Bugaboo Cameleon - Tailored Fabric...
The brake button on my bugaboo chameleon is jammed and won't release therefore the brake won't work , what an i do
Your best bet is to contact www.bugaboo.com for a brake assembly replacement. If the break is permanently in the 'on' position, then gently push it forward (as if to put in on) whilst pushing the white release button, this should release the mechanism. If this is still within it's warranty, see your retailer for help.,
I hope this helps.
Sep 01, 2009 | Bugaboo Cameleon Jogger
Chameleon: brake not secure and extendable handle lock jammed
This has been solved elsewhere on this site - do a search, but spell Cameleon without the H in it and you'll find it
Aug 31, 2009 | Bugaboo Cameleon Jogger
Bugaboo Hand Brake Mechanism
I have easily solved this problem here in Brazil, where there are no Bugaboo retailers or assistance. I just opened the brake lever case by unscrewing it and fixed the white piece in its correct position. It's very easy to figure it out.
The only special care you have to take is not to lose the spring that is inside it.
I've read the solution here in this site wherelse.
Nov 03, 2008 | Bugaboo Cameleon Jogger
Bugaboo brake pad is not aligned with wheel
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Mar 29, 2008 | Bugaboo Cameleon Jogger
Out of warranty bugaboo cameleon
CONTACT BUGABOO
Dec 22, 2007 | Bugaboo Cameleon Jogger
Bugaboo Gecko Stroller
CONTACT BUGABOO
Nov 19, 2007 | Bugaboo Gecko - Green Standard Stroller
Bugaboo Cameleon Jogger Logo
700 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
